Old 07-09-2003, 12:19 AM
Klaus's Avatar
Klaus Klaus is offline
Document ID# 1338332
2003 HUMMER H2
Service VME - Passenger Floor Carpet Wet - hose HVAC leak module moisture pan right side sunroof top water #PI01142 - (05/29/2003)
SERVICE VME
Should a customer indicate that the passenger side floor carpet is wet, the most probable cause is that water is finding its way from the plenum area into the HVAC module through an opening at the top referred to as the chimney. The source of the water is the R/H sunroof drain hose. Reposition the hose or extend it to redirect the water away from the opening in the HVAC module.
A bulletin and service kit will soon be made available.
Please follow this diagnosis process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed. If these steps do not resolve the condition, please contact GM TAC for further diagnostic assistance. This diagnostic approach was developed for the vehicle with the VIN you entered and should not be automatically be used for other vehicles with similar symptoms.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
2003 HUMMER H2
Klaus's Avatar
2003 HUMMER H2
SERVICE VME
2003 HUMMER H2
