Old 12-22-2002, 06:56 PM
nkmoon nkmoon is offline
nkmoon is off the scale
I am trying to remove the off road light bar from my H2. I know that the bars are supposed to slide off the end at the rear. My question is how do I remove the plastic stop at the end? I pull up the plastic tab, but I can't get it to release. I know this has to be something pretty simple but I can't figure it out. Any help would be greatly appreciated. This isn't even mentioned in the manual.
Old 12-22-2002, 07:44 PM
Texas Red's Avatar
Texas Red is off the scale
I had the same question. See answers in same topic under Technical Discussion section.
Jim
Red H2 in Texas
Jim
2008 H3 Graphite Lux
Old 12-22-2002, 07:58 PM
OUSUCKS OUSUCKS is offline
OUSUCKS is off the scale
I just put my light bar back on (moved to a new house) and I can't believe it fit in my garage! You have to use the screwdriver to move the tab. Then just put you finger in the little circle and pull. They are not fastened by any screws. The first time I did it I thought I was going to break it. Now they pop off real easily.
