Old 02-06-2005, 02:11 AM
BLOWN H2 BLOWN H2 is offline
BLOWN H2 is off the scale
Here is another pic of my 03 H2.
Tim Andrews 03 Black H2 lux
Old 02-06-2005, 02:17 AM
One more
Old 02-06-2005, 02:19 AM
Here is one more
Old 02-06-2005, 02:30 AM
H2Finally's Avatar
Very nice! Off-roading MAX-BLING!
Can BLING Get You Home?
Old 02-06-2005, 02:33 AM
LasVegas LasVegas is offline
LasVegas is off the scale
Hey man. Try 640x480 max pic size next time. Couldn't scroll far enough to see the whole picture.
Jonahs
Old 02-06-2005, 02:44 AM
Hi SFOX The Diff cover is made by a company called PML you can find them at yourcovers.com it goes for $175.00 I put it on when I swapped the gears out to 4.88's. And how do I change the picture size to 640x480? Any help would be appreciated. And thank you all for your nice comments.
Old 02-06-2005, 02:50 AM
One more pic this was at the end of the trip in Hotsprings Va
Old 02-06-2005, 03:05 AM
Tim. Don't know what application you're using for the pics but all have the ability to resize. Even in MS Paint select image/stretch/skew and alter size. Nice looking rig!
Jonahs
Old 02-06-2005, 03:26 AM
Thank you Jonahs for the help and complements I resized this one hope it works
Old 02-06-2005, 03:34 AM
Here is a closer look at the differential cover
Old 02-06-2005, 03:43 AM
Great pics. Black looks awesome brown.
To do a simple resize, go here to the Microsoft Image Resizer and download:
http://download.microsoft.com/downlo...ertoySetup.exe
Simply right click the image and choose the smallest available. Then delete the original if you want, but be sure to post the "small" pic.
Old 02-06-2005, 03:54 AM
Thanks KenP that was pretty painless
Old 02-06-2005, 03:55 AM
Thank you KenP that was pretty painless
Old 02-06-2005, 04:11 AM
I think I have the hang of it now thanks again for the info.
Old 02-08-2005, 04:17 AM
Andre Andre is offline
Andre is off the scale
what are you running for wheels and tires, also lift?
Andre
Old 02-08-2005, 11:53 AM
Hi Andre I am running a FABTECH 6 inch lift with Multiple front shock system and FABTECH skid plates and duel steering stabilzers. The gears were swapped out to 4.88 with a e-locker in the front. The wheels are MKW 20x11 the tires are 39x13.50x20 IROC radials. Since that photo I have changed the trailing arms and panhard rod. Also running HOTCHKIS front and rear sway bars. When the tie rods come in at fabtech I will be replacing those along with the pitman arm and idler arm. I have a set of fox racing shocks with remote resevoirs I have not had time to install yet.
Old 02-08-2005, 07:49 PM
1BADH2 1BADH2 is offline
1BADH2 is off the scale
Blown that is a nice truck! Did you have to cut anything with the Fabtek?
Old 02-09-2005, 06:36 PM
Hi 1BADH2 I used to have the same plate on my Dodge but it said 1BADRAM. You have to cut the ear off the front differential houseing and there is some minor welding. If you go to the FABTECH website you can download the instructions. Thank you for the complement also.
