Old 10-23-2005, 01:05 PM
Is there a drain for the track that the roof rails slide? There are also some other little square nooks on the roof that can hold water that only have a screw at the bottom. Are these areas a concern for water/rust/corrostion?
Old 10-23-2005, 02:21 PM
Any water in the roof rail channels should run down a-pillar in the front.
Old 10-24-2005, 03:01 AM
H3 Builder's Avatar
H3 Builder H3 Builder is offline
H3 Builder is an unknown quantity at this point
The sunroof has, I believe 4 drain hoses. Roof rack, zero.
Old 10-24-2005, 04:40 AM
wannabeH3's Avatar
everything seems to go down my A-pillar
(with insurance)
Old 10-24-2005, 07:46 AM
There is a grove in the roof rails (front to rear), I had researched this as a place to run a CB antenna from the rear to the front if using a rood mounted magnetic antenna. Whether it is designed for water drainage...don't know for sure.
