Old 12-03-2002, 09:28 PM
Vaka Humm Vaka Humm is offline
Location: Boca Grande, Fl. Best Damn Tarpon Fishing On The Planet
Vaka Humm is off the scale
I just installed the SMC tire carrier and noticed how far it is from the reciver to the back of the spare tire. Has anyone towed with this set-up? What did you use for a tow bar (the bar the hitch ball is attached to)? How long is it and where did you get it? Also I want to use the front hitch to put my boats in and out of the water, what did you use for that hitch bar and pin? Thanks for any info.
Old 12-03-2002, 10:20 PM
Arizona Hummerboy's Avatar
I tow a trailer most of the time with my H2, I do have the tire carrier on the back, I do use a 8 inch drop down hich, I tow a quad trailer with no problem at all.
www.awesomesuccess4u.com
Old 12-04-2002, 12:16 AM
Brad Brad is offline
Brad is off the scale
I haul a 4 wheeler trailer that I hunt with. I have an extended drop down hitch that I got at Tractor Supply (TSC).
It works great, but the safety chains are to short to reach my receiver.
Old 12-07-2002, 01:53 PM
kelleymac2000 kelleymac2000 is offline
kelleymac2000 is off the scale
If you've got it, be sure to try an 8" drop. We started with a 6", brought it home, hooked up the boat, it was PERFECT. Started the truck, and my air suspension kicked the rear end up 2".
We went back for the 8". [img]/infopop/emoticons/icon_biggrin.gif[/img]
