Old 03-31-2004, 08:33 PM
TroysH2 TroysH2 is offline
TroysH2 is off the scale
After reading a recent post on this issue, I noticed the same condition on my 03 H2. There was an thin/slightly damp oil spread out from the output shaft seal and surrounding area.
Made appointment Monday a.m the 29th to fix/replace (1) oil leak/seal (2) Driver side pillar vibration (3) Recall on replacing the ignition switch. (4) SERVICE 4WD Indication.
Almost three days later they (1) Replaced Transfer Case Shift Module (this was the fix for the SERVICE 4WD Indicator) (2) They forgot to fix/service pillar vibration (3) Forgot to replace recall issue-ignition switch replacement.
Most important (4) they said the leak was from the vent cover seal on the differential housing and replaced the O Ring on vent cover.
I personally checked this before and such a leak from this location would be sooo... obvious.
Now, I have a big leak from the Vent Cover Seal.
Questions:
(1) Has anyone else had such a difficult time getting good service from their Hummer Dealership?
(2) How do I get them to replace the output shaft seal?
Thanks again,
Troy
