Old 04-10-2006, 07:47 PM
Originally posted by aetherH3:
I used to have a few jeeps a few years back and they had some great rocker protection that integrated steps into them. I'm not a big fan of Nerf Bars because they hang so low and don't protect anything. So.... I was thinking, if anyone has any pull with any of the H3 accessories manufacturers... or if you are capable of making these, i think there would be a good market for them. The photo below is what i would like to see except the "step" should not be angled that much. What do you all think?
Interesting, but not sure if it could be done on the H3. The Jeep has about four inches of rocker panel from the bottom of the vehicle to the bottom of the door (TJs in previous years). Whereas, with the H3, the top of the rocker protectors is pretty darn close to the bottom of the door. Putting steps that high might create a clearance problem. (I'm taking this out of memory on a Jeep, and too darn tired to go check clearances with a H3).
The other problem would be this would make the step up as high to get into the vehicle as without the step. When that happens, why have a step?
