Old 12-03-2004, 04:00 AM
package deal package deal is offline
package deal is off the scale
has anyone towed a h1 for an extended period of time such as behind a motorhome? any problems with doing this?
Old 12-03-2004, 10:32 AM
ckhagman ckhagman is offline
ckhagman is off the scale
from what i have heard you should disconnect the drive shafts first. I would personally put it on a trailer. Charlie Piper makes a disconnect for the front drive shaft so that you can drive in 2-wheel drive also. Dave Breggin of Blue Hummer Outfitters and Scot Smith from Southern Axle are developing a new t-case for the truck so it has more than the factory options. 2-wheel drive, 4 high, 4 low 4 low lock, 4 low unlocked, etc. I do not remember the exact specs but it is currently installed in a few trucks for testing purposes.
http://www.penta-nut.com
The Most Sirius Off-Road Vehicle
Old 12-04-2004, 01:55 AM
Shawn from Angry Iron Shawn from Angry Iron is offline
Shawn from Angry Iron is off the scale
That is why you have a nutral position on your Tcase shifter. It can be flat towed the military even have tow bars for them. Your owners manuel should cover this. shift both trans and t case into nutral and you can tow it all dat long.
Shawn
85 HMMWV
Angry Iron www.angryiron.com
Taking the High Ground
