Old 10-14-2003, 11:36 PM
SRFCASTR SRFCASTR is offline
SRFCASTR is off the scale
Recently while using a loaner H2 (Not yet taken delivery of my 2004), my neighbor offered the following:
"you are NOT really buying one of those, are you???"
My Reply: ABSOLUTELY
"it is a socially irresponsible vehicle"
My Reply: THIS IS AMERICA
What is your oposition??
"It's size, it's fuel consumption."
Recalling that I so often see a Lincoln Navigator parked (VisitoR0 in his driveway, I offered "If this is your response to the H2 then I feel sorry for the (&$*^# you must have given your Linc Nav owner." He was totally surprised and I continued:
The H2 is EXACTLY the same HEIGHT
1 inch wider
Less than 6% heavier
Gets about 2.5 miles less MPG
and is 16 SIXTEEN inches shorter.
AGAIN he was stunned.
I went on the suggest he investigate and speach from knowledge rather than ignorance. Lastly I suggested he check out the Excursion amd Denali XL.
I haven't heard from him since. I suspect he is doing his homework now . NOT!! He would rather be ignorant and believe the tree huggers.
I plan to park it on the strret in front of his house OFTEN
SRFCASTR
1 inch wider
SRFCASTR
Old 10-14-2003, 11:40 PM
hummer33 hummer33 is offline
hummer33 is off the scale
TRUE DAT!!!!!!!!!!
Old 10-15-2003, 12:06 AM
You did the right thing SRF. Normally when confronted like that, I usually pull out my Little General. Usually ends the conversation.
Old 10-15-2003, 12:14 AM
Albie's Avatar
Albie Albie is offline
Albie is off the scale
its ok homeboy was just busting out the hateraid
