Old 02-03-2006, 12:54 PM
HUMRCHIC's Avatar
HUMRCHIC HUMRCHIC is offline
HUMRCHIC is off the scale
I just bought this last night.
Bull Bar Do you think it would look OK? I have't seen too many H3's with it. I will be adding the lights too. Probably the PIAA 520 Crystal Ion, as soon as I find a deal on them. Can't see spending that much mula on something I legally can't use. LOL. And advice is appreciated.
2006 H3 in Shadow Green Metallic. Lux. package, Off-Road Pkg, Chrome Pkg, Stainless Hood Vent w/ Handles, Chrome Gas Cap, DVD HDRST, 7speaker Monsoon system. Sunroof,XM. Chrome Nerf bars.
See where other H3 owners are. Click Here
http://www.frappr.com/hummerh3owners
Join our Hummer Community and CHAT live with other H3 owners!!!
http://groups.msn.com/H3Owners
HUMRCHIC's Avatar
Old 02-03-2006, 01:45 PM
ree's Avatar
ree ree is offline
Find, Find, Find, Find, Find, Find, Find!
http://elcova.com/groupee/forums/a/tpc/f/4871031121/m/7...461005351#7461005351
http://elcova.com/groupee/forums/a/tpc/f/4871031121/m/3...641068051#3641068051
As for legality of lights, it depends on the statutes where you live.
West Virginia Code is here: http://www.legis.state.wv.us/WVCODE/...frm3Banner.cfm
One of the sections containing fog is this one
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content"> §17C-15-17. Spot lamps and other auxiliary lamps.
(a) Spot lamps. -- Any motor vehicle except a public utility company maintenance vehicle may be equipped with not more than one spot lamp and every lighted spot lamp shall be so aimed and used upon approaching another vehicle that no part of the high-intensity portion of the beam will be directed to the left of the prolongation of the extreme left side of the vehicle nor more than one hundred feet ahead of the vehicle. A public utility company maintenance vehicle may be equipped with more than one spot lamp but all lighted spot lamps shall be aimed and used in conformity to the requirements of this subsection.
(b) Fog lamps. -- Any motor vehicle may be equipped with not more than two fog lamps mounted on the front at a height not less than twelve inches nor more than thirty inches above the level surface upon which the vehicle stands and so aimed that when the vehicle is not loaded none of the high-intensity portion of the light to the left of the center of the vehicle shall at a distance of twenty-five feet ahead project higher than a level of four inches below the level of the center of the lamp from which it comes.
(c) Auxiliary passing lamp. -- Any motor vehicle may be equipped with not more than one auxiliary passing lamp mounted on the front at a height not less than twenty-four inches nor more than forty-two inches above the level surface upon which the vehicle stands and every auxiliary passing lamp shall meet the requirements and limitations set forth in this article.
(d) Auxiliary driving lamp. -- Any motor vehicle may be equipped with not more than one auxiliary driving lamp mounted on the front at a height not less than sixteen inches nor more than forty-two inches above the level surface upon which the vehicle stands and every such auxiliary driving lamp shall meet the requirements and limitations set forth in this article.
(e) Roof-mounted off-road light bar lighting device. -- Any motor vehicle may be equipped with a roof-mounted off-road light bar lighting device comprised of multiple lamps: Provided, That whenever the vehicle is operated or driven upon any road or highway of this state, the roof-mounted off-road light bar lighting device shall be turned off and covered with an opaque covering that prohibits light from being emitted while the vehicle is being operated on any road or highway of this state. </div></BLOCKQUOTE>
So it depends exactly which light pattern you the lamps have, what height you mount them, and how you will be aiming them. Tf they're aimed as brights, WV may require that the vehicle they're mounted on display it's brights indicator on the dash when they're on. Which would they'd need to be wired to the brights circuit to be legal. Not all states require this. Also, check out the statutes for neighboring states if you drive in them.
It's all public data and it's all online.
'03 pewter base H2
Old 02-03-2006, 01:48 PM
Ipedog's Avatar
Ipedog Ipedog is offline
See this Thread
Rob (Ipedog - Say "Ip-E-Dog")
Black Sheep HUMMER Squadron
Old 02-03-2006, 07:36 PM
CzechMan CzechMan is offline
CzechMan is off the scale
Yeah, I was looking at it too and I do kind of like it, but I finally saw some of the other brush guards mounted and will probably opt for one of the full face ones.
Old 02-04-2006, 12:44 AM
HUMRCHIC's Avatar
OK< OK < I cancelled it. I emailed them and told them it just won't work for me. So I ordered the Chrome deck vent instead and splash gaurds and a Hummer chrome fuel door. Thanks guys!
