Old 03-01-2004, 12:43 AM
I need some assistance with these problems. I would prefer to fix myself before taking to the dealership. I have searched, of course, and cannot find what I need here.
1. Key fob not working. New battery and all. I seem to remember something about holding the "lock" and "unlock" buttons down together but could not locate it. So I tried it for a minute and nothing.
2. None of the electronic switches work on the passenger side front. This includes the window, and seat heaters.
3. When turning off the truck the electronics, ie radio, would still work for a few minutes. This does not happen anymore. When I turn off the truck, everything shuts down.
Thanks in advance.
Black Lingenfelter Lux
Thanks in advance.
Old 03-01-2004, 01:20 AM
Klaus's Avatar
Klaus Klaus is offline
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD><TITLE>Service Information</TITLE>
<META http-equiv=Content-Type content="text/html; charset=windows-1252">
<META content="Microsoft FrontPage 5.0" name=GENERATOR></HEAD>
<BODY bgColor=#ffffff>
<FORM name=topNavForm action=/servlets/CellHandler>
<TABLE width="100%" align=center>
<TBODY>
<TR>
<TD width="25%" slign="LEFT"></TD>
<TD align=middle width="50%">Document ID# 1270477
2003 HUMMER
H2
</TD>
<TD align=right width="25%"></TD></TR></TBODY></TABLE>
<HR>
</FORM>
<H1>Remote Keyless Entry (RKE) System Inoperative (Reprogram Passenger Door
Module) #03-08-52-001C - (03/17/2003)</H1>Remote Keyless Entry (RKE) System
Inoperative (Reprogram Passenger Door Module)
2003 Cadillac Escalade, Escalade ESV, Escalade EXT</P>
2003 Chevrolet Avalanche, Silverado, Suburban, Tahoe</P>
2003 GMC Sierra, Yukon, Yukon XL</P>
2003 HUMMER H2</P>
From Start of Production (SOP) through December, 2002 for the 2003 Model Year
</P>
This bulletin is being revised to provide the latest service information.
Please discard Corporate Bulletin Number 03-08-52-001B (Section 08 -- Body and
Accessories).</P><A name=ss1-1270477><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1270477&amp;psdid=293&amp;evc= sm#ss1-1270477">
<H5>Condition</A></H5>
Some customers may comment on any of the following conditions:</P>
<UL type=BULLET>
<LI>The RKE key fob does not function.
<LI>The RKE has a very limited range.
<LI>The passenger door will not unlock from the passengers or drivers door
switches.
<LI>The passenger door window is inoperative. </LI>[/list]<A name=ss2-1270477><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1270477&amp;psdid=293&amp;evc= sm#ss2-1270477">
<H5>Correction</A></H5>
<FONT color=brown>
<H4>Important</H4>
For clarification purposes, the following information is provided. The
components involved in this bulletin are known by various names. The Service
Information Document ID #849813 refers to the component as the Door Lock and
Side Window Switch. General Motors Service Parts refers to the components as
SWITCH DR LK &amp; SI WDO. Within this component is a micro processor that is
referred to as the Passenger Door Module (PDM). Techline equipment refers to the
component as the PDM Passenger Door Module. This bulletin addresses issues with
the software of the microprocessor in the Passenger Door Module
(PDM).</P></FONT>
</P>
Perform the following procedure step by step (do not skip a step) to
determine the proper course of action.</P>
<FONT color=brown>
<H4>Important</H4>
Verify the software version in your Tech2. If the software is not
23.001 or newer, your Tech2 software needs to be updated.</P></FONT>
</P>
  1. <LI type=1>Determine the production date of the vehicle by viewing the
    certification label on the driver's door.
    <UL type=BULLET>
    <LI>If the vehicle's month of production is PRIOR to 01/03, go to Step 2.
    <LI>If the vehicle's month of production is 01/03, THIS BULLETIN DOES NOT
    APPLY. Refer to Customer Satisfaction Program bulletin 03011, published
    March 2003.
    <LI>If the vehicles month of production is 02/03 or newer, this bulletin
    does not apply. Refer to published Service Information for the symptom
    experienced by the customer. </LI>
<LI type=1>Use the Tech2 to determine the PDM operational software
release number.
<UL type=BULLET>
<LI>With the Tech2 installed and powered up, verify the software
version. If the software is not 23.001 or newer, your Tech2 software
<LI>Press Enter.
<LI>Select: Diagnostics.
<LI>Select model year: 2003.
<LI>Select: Light truck.
<LI>Select : Body.
<LI>Select the proper Product line.
<LI>Select the proper HVAC Type.
<LI>Select the proper Radio System type.
<LI>Select: Passenger Door Module.
<LI>Select: Data display.
<LI>Select: Module 1 information.
<UL type=SQUARE>
<LI>If a number is displayed following "Operational S/W Part Number" ,
continue with the next bullet.
<LI>If an (*) is displayed following "Operational S/W Part Number" , go to
Step #3 below. </LI>[/list] <LI>If the "Operational S/W Part Number" is 15181562, 15186199 or 15186460,
exit out of this bulletin procedure. Refer to Service Information to
diagnose the condition reported by the customer (the vehicle has the most
current software as of the date of this bulletin).
<LI>Exit to the Main Menu.
<LI>Perform normal SPS reprogramming of the Passenger Door Module.
<LI>Go to Step 4. </LI>[/list] <LI type=1>If an (*) is displayed following "Operational S/W Part Number" ,
return to the screen which will allow you to select the Passenger Door Module
by pressing Exit (3) times.
<UL type=BULLET>
<LI>Select: Special Functions.
<LI>Select: Refresh.
<LI>Follow all on-screen instructions.
<LI>When the Tech2 displays "Refresh Procedure Successful", Exit to
the Main Menu.
<LI>Go to Step 4. </LI>[/list] <LI type=1>Return the vehicle to the customer. </LI>[/list]<A name=ss3-1270477><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1270477&amp;psdid=293&amp;evc= sm#ss3-1270477">
<H5>Warranty Information</A></H5>
For vehicles repaired under warranty, use:</P>
<TABLE width="100%" border=1>
<TBODY>
<TR>
<TH vAlign=bottom align=middle>
Labor Operation</P></TH>
Description</P></TH>
Labor Time</P></TH></TR>
<TR>
<TD vAlign=center align=middle>
N4808</P></TD>
Module, Body Control (BCM) - Reprogram</P></TD>
0.4hr</P></TD></TR></TBODY></TABLE>
</P>
<TABLE width="100%">
<TBODY>
<TR>
<TD align=left width=778><FONT size=1>GM bulletins are intended for use by
professional technicians, NOT a "do-it-yourselfer". They are written
to inform these technicians of conditions that may occur on some vehicles,
or to provide information that could assist in the proper service of a
vehicle. Properly trained technicians have the equipment, tools,
safety instructions, and know-how to do a job properly and safely.
If a condition is described, DO NOT assume that the bulletin applies to
your vehicle, or that your vehicle will have that condition. See
your GM dealer for information on whether your vehicle may benefit from
the information.
</FONT></TD>
<TD align=middle width=42></TD>
<TD align=middle width=167><FONT size=2>WE SUPPORT VOLUNTARY TECHNICIAN
CERTIFICATION
</FONT></TD></TR></TBODY></TABLE>
<P align=center>© Copyright General Motors Corporation. All Rights
Reserved.
</P>
<FORM name=bottomNavForm>
<HR>
<TBODY>
<TR>
2003 HUMMER
H2
</TD>
<TD align=right width="25%"></TD></TR></TBODY></TABLE></FORM></BODY></HTML>
Old 03-01-2004, 01:23 AM
Klaus's Avatar
<TBODY>
<TR>
<TD align=middle width="50%">Document ID# 863106
2003 HUMMER
H2
</TD>
<HR>
</FORM>
<H1>Power Window Inoperative - Passenger Door Front Door</H1>
<TBODY>
<TR>
Step</P></TH>
Action</P></TH>
Yes</P></TH>
No</P></TH></TR>
<TR>
<TD vAlign=top align=left colSpan=4>
Schematic Reference: <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=11282&amp;RefDoc=863106">Power
Window Schematics</A>
</P>
Connector End View Reference: <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=11706&amp;RefDoc=863106">Power
Door Systems Connector End Views</A>
</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S01>
1</P></A></TD>
<TD vAlign=top align=left>
Did you perform the Door Systems Diagnostic System Check?</P></TD>
<TD vAlign=bottom align=middle>
Go to Step2
</P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=12131&amp;RefDoc=863106">Diagno stic
System Check - Door Systems</A> </P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S02>
2</P></A></TD>
  1. <LI type=1>Turn ON the ignition, with the engine OFF.
    <LI type=1>Disable the window lockout function.
    <LI type=1>Operate the passenger front power window in the UP and DOWN
    directions from the passenger switch. </LI>
Does the passenger front power window operate properly?</P></TD>
Go to Step3
</P></TD>
Go to Step4
</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S03>
3</P></A></TD>
Operate the passenger front power window in the UP and DOWN directions
from the master switch.</P>
Does the passenger front power window operate properly from the master
switch?</P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=62112&amp;RefDoc=863106">Testin g
for Intermittent and Poor Connections</A> in Wiring Systems </P></TD>
Go to Step5
</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S04>
4</P></A></TD>
  1. <LI type=1>Install a scan tool.
    <LI type=1>Monitor the window lockout data parameter in the driver door
    module inputs list.
    <LI type=1>Activate the window lockout switch to both the On and OFF
    positions. </LI>
Does the window lockout data parameter change state
appropriately?</P></TD>
Go to Step5
</P></TD>
Go to Step16
</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S05>
5</P></A></TD>
Monitor the passenger front window status data parameter in both the
driver and passenger door module input lists.</P>
Do either passenger front window status data parameters display an
active state without a window switch activation?</P></TD>
Go to Step6
</P></TD>
Go to Step7
</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S06>
6</P></A></TD>
Is the active switch displayed in the driver door module input
list?</P></TD>
Go to Step16
</P></TD>
Go to Step15
</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S07>
7</P></A></TD>
  1. <LI type=1>Monitor the passenger front window status in the passenger
    door module inputs list.
    <LI type=1>Activate the passenger power switch on the passenger door
    module in the up and down positions. </LI>
Does the window status data parameter change accordingly?</P></TD>
Go to Step8
</P></TD>
Go to Step15
</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S08>
8</P></A></TD>
  1. <LI type=1>Monitor the passenger front window status in the driver door
    module inputs list.
    <LI type=1>Activate the passenger front power window switch on the
    driver door module in the up and down positions. </LI>
Go to Step9
</P></TD>
Go to Step16
</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S09>
9</P></A></TD>
  1. <LI type=1>Connect a test lamp to a good ground.
    <LI type=1>Backprobe the battery positive voltage circuit in
    connectorC1 cavityD at the passenger door module. </LI>
Does the test lamp illuminate?</P></TD>
Go to Step10
</P></TD>
Go to Step18
</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S10>
10</P></A></TD>
  1. <LI type=1>Disconnect the passenger front power window motor.
    <LI type=1>Probe the power window motor up control circuit at the power
    window motor harness connector.
    <LI type=1>Activate the power window switch to the UP position. </LI>
Does the test illuminate?</P></TD>
Go to Step11
</P></TD>
Go to Step13
</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S11>
11</P></A></TD>
  1. <LI type=1>With the test lamp still connected to a good ground, probe
    the power window motor down control circuit.
    <LI type=1>Activate the power window switch to the DOWN position.
    </LI>
Go to Step12
</P></TD>
Go to Step14
</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S12>
12</P></A></TD>
  1. <LI type=1>Connect a test lamp between the power window motor up and
    down control circuits.
    <LI type=1>Activate the power window switch to the UP and DOWN
    positions. </LI>
Does the test lamp illuminate in both positions?</P></TD>
Go to Step17
</P></TD>
Go to Step15
</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S13>
13</P></A></TD>
Test for an open or short to ground in the power window motor up
control circuit. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=62194&amp;RefDoc=863106">Circui t
Testing</A> and <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=61965&amp;RefDoc=863106">Wiring
Repairs</A> in Wiring Systems.</P>
Did you find and correct the condition?</P></TD>
Go to Step22
</P></TD>
Go to Step15
</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S14>
14</P></A></TD>
Test for an open or short to ground in the power window motor down
Testing</A> and <A
Go to Step22
</P></TD>
Go to Step15
</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S15>
15</P></A></TD>
Inspect for poor connections at the passenger door module. Refer to <A
for Intermittent and Poor Connections</A> and <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=61973&amp;RefDoc=863106">Connec tor
Go to Step22
</P></TD>
Go to Step19
</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S16>
16</P></A></TD>
Inspect for poor connections at the driver door module. Refer to <A
Go to Step22
</P></TD>
Go to Step20
</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S17>
17</P></A></TD>
Inspect for poor connections at the passenger front power window motor.
Refer to <A
Go to Step22
</P></TD>
Go to Step21
</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S18>
18</P></A></TD>
Repair the open or short to ground in the battery positive voltage
Did you complete the repair?</P></TD>
Go to Step22
</P></TD>
--</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S19>
19</P></A></TD>
<FONT color=brown>
<H4>Important</H4>
Perform the set up procedure for the passenger door module. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=71878&amp;RefDoc=863106">Servic e
Programming System (SPS)</A> in Programming.</P></FONT>
</P>
Replace the passenger door module. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=67591&amp;RefDoc=863106">Switch
Replacement - Door Lock and Side Window - Passenger</A> .</P>
Go to Step22
</P></TD>
--</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S20>
20</P></A></TD>
<FONT color=brown>
<H4>Important</H4>
Perform the set up procedure for the driver door module. Refer to <A
</P>
Replace the driver door module. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=67590&amp;RefDoc=863106">Switch
Replacement - Door Lock and Side Window - Driver</A> .</P>
Go to Step22
</P></TD>
--</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S21>
21</P></A></TD>
Replace the passenger front power window motor. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=11922&amp;RefDoc=863106">Window
Regulator Motor Replacement - Front Door</A> .</P>
Go to Step22
</P></TD>
--</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S22>
22</P></A></TD>
Operate the system in order to verify the repair.</P>
Did you correct the condition?</P></TD>
System OK</P></TD>
Go to Step3
<HR>
<TBODY>
<TR>
2003 HUMMER
H2
</TD>
Old 03-01-2004, 01:24 AM
Klaus's Avatar
<TBODY>
<TR>
<TD align=middle width="50%">Document ID# 792173
2003 HUMMER
H2
</TD>
<HR>
</FORM>
<H1>Retained Accessory Power (RAP) Inoperative</H1>
<TBODY>
<TR>
Step</P></TH>
Action</P></TH>
Yes</P></TH>
No</P></TH></TR>
<TR>
<TD vAlign=bottom colSpan=4>
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=56172&amp;RefDoc=792173">Retain ed
Accessory Power (RAP) Schematics</A> </P>
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=62031&amp;RefDoc=792173">Master
Electrical Component List</A> in Wiring Systems
</P></TD></TR>
<TR>
1</P></TD>
Did you perform the Diagnostic System Check - Retained Accessory
Power?</P></TD>
Go to Step2
</P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=56208&amp;RefDoc=792173">Diagno stic
System Check - Retained Accessory Power</A> </P></TD></TR>
<TR>
2</P></A></TD>
  1. <LI type=1>Close all of the doors.
    <LI type=1>Turn OFF the ignition. </LI>
Do all the retained accessory power functions operate during the RAP
time?</P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=62112&amp;RefDoc=792173">Testin g
for Intermittent and Poor Connections</A> in Wiring Systems</P></TD>
Go to Step3
</P></TD></TR>
<TR>
3</P></A></TD>
<TD>
Does only sunroof exhibit this symptom?</P></TD>
Go to Step5
</P></TD>
Go to Step4
</P></TD></TR>
<TR>
4</P></A></TD>
<TD>
  1. <LI type=1>Install a scan tool. Select diagnostic circuit check and then
    class2 power mode.
    <LI type=1>Wait 5seconds then turn the ignition OFF.
    <LI type=1>Wait the time-out for RAP. </LI>
Did the scan tool display the RAP power mode then time-out, and display
Off-Awake power mode?</P></TD>
Go to Step5
</P></TD>
Go to Step15
</P></TD></TR>
<TR>
5</P></A></TD>
  1. <LI type=1>Turn OFF the ignition.
    <LI type=1>Disconnect the sunroof relay.
    <LI type=1>With a test lamp that is connected to a good ground, probe
    the battery positive voltage circuit of the sunroof relay. </LI>
Go to Step6
</P></TD>
Go to Step12
</P></TD></TR>
<TR>
6</P></A></TD>
<TD>
  1. <LI type=1>Connect a test lamp between the relay coil circuits of the
    sunroof relay.
    <LI type=1>Turn the ignition ON, with the engine OFF. </LI>
Go to Step9
</P></TD>
Go to Step7
</P></TD></TR>
<TR>
7</P></A></TD>
<TD>
Test the RAP supply voltage circuit for a short to ground or an
open.</P>
Turn the ignition ON, with the engine OFF, when testing for a short to
voltage. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=62194&amp;RefDoc=792173">Circui t
Testing</A> and to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=61965&amp;RefDoc=792173">Wiring
Go to Step17
</P></TD>
Go to Step8
</P></TD></TR>
<TR>
8</P></A></TD>
<TD>
Test the sunroof relay ground circuit for an open. </P>
Go to Step17
</P></TD>
Go to Step15
</P></TD></TR>
<TR>
9</P></A></TD>
<TD>
  1. <LI type=1>Connect a fused wire jumper across the relay switched
    circuits of the sunroof relay.
    <LI type=1>Attempt to operate the sunroof. </LI>
Does the sunroof operate normally?</P></TD>
Go to Step11
</P></TD>
Go to Step10
</P></TD></TR>
<TR>
10</P></A></TD>
Repair the sunroof relay switch output circuit. Refer to <A
Did you complete the replacement?</P></TD>
Go to Step17
</P></TD>
--</P></TD></TR>
<TR>
11</P></A></TD>
Inspect for poor connections at the sunroof relay. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=61973&amp;RefDoc=792173">Connec tor
Go to Step17
</P></TD>
Go to Step14
</P></TD></TR>
<TR>
12</P></A></TD>
<TD>
Test the sunroof supply voltage circuit for a short to ground.</P>
Go to Step17
</P></TD>
Go to Step13
</P></TD></TR>
<TR>
13</P></A></TD>
Repair the battery positive voltage circuit of the sunroof relay. Refer
to <A
Go to Step17
</P></TD>
--</P></TD></TR>
<TR>
14</P></A></TD>
Replace the sunroof relay.</P>
Go to Step17
</P></TD>
--</P></TD></TR>
<TR>
15</P></A></TD>
<TD>
Inspect for poor connections at the harness connector of the BCM. Refer
to <A
Go to Step17
</P></TD>
Go to Step16
</P></TD></TR>
<TR>
16</P></A></TD>
<TD>
<FONT color=brown>
<H4>Important:</H4>
Perform the module setup procedure if required.</P></FONT>
</P>
Replace the BCM. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=9193&amp;RefDoc=792173">Control
Module References</A> in Body Control System.</P>
Did you complete the procedure?</P></TD>
Go to Step17
</P></TD>
--</P></TD></TR>
<TR>
17</P></A></TD>
System OK</P></TD>
Go to Step3
<HR>
<TBODY>
<TR>
2003 HUMMER
H2
</TD>
Old 03-01-2004, 01:26 AM
Klaus's Avatar
<TBODY>
<TR>
<TD align=middle width="50%">Document ID# 1256458
2003 HUMMER
H2
</TD>
<HR>
</FORM>
<H1>Customer Satisfaction - Remote Keyless Entry (RKE) System Inoperative #03011
- (03/06/2003)</H1></TABLE>03011 -- Remote Keyless Entry (RKE) System
Inoperative
2003 Cadillac Escalade, Escalade EXT, Escalade ESV</P>
2003 Chevrolet Silverado, Avalanche, Tahoe, Suburban</P>
2003 HUMMER H2</P><A name=ss1-1256458><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1256458&amp;psdid=293&amp;evc= sm#ss1-1256458">
On some 2003 model year Cadillac Escalade, Escalade EXT, and Escalade ESV;
Chevrolet Silverado, Avalanche, Tahoe, and Suburban; GMC Sierra, Yukon, and
Yukon XL; and HUMMER H2 vehicles, the passenger door module (PDM) may become
inoperative. An inoperative PDM would cause loss of function for the remote
keyless entry, front passenger power window, lock, mirror and heated seat
functions.</P><A name=ss2-1256458><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1256458&amp;psdid=293&amp;evc= sm#ss2-1256458">
Dealers are to reprogram the PDM.</P><A name=ss3-1256458><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1256458&amp;psdid=293&amp;evc= sm#ss3-1256458">
<H5>Vehicles Involved</A></H5>
Involved are certain 2003 model year Cadillac Escalade, Escalade EXT, and
Escalade ESV; Chevrolet Silverado, Avalanche, Tahoe, and Suburban; GMC Sierra,
Yukon, and Yukon XL; and HUMMER H2 vehicles built within these VIN
breakpoints:</P>
<TBODY>
<TR>
Year</P></TH>
Division</P></TH>
Model</P></TH>
From</P></TH>
Through</P></TH></TR>
<TR>
2003</P></TD>
Cadillac</P></TD>
Escalade</P></TD>
3R100413</P></TD>
3R216634</P></TD></TR>
<TR>
2003</P></TD>
Cadillac</P></TD>
Escalade EXT</P></TD>
3G107005</P></TD>
3G219587</P></TD></TR>
<TR>
2003</P></TD>
Cadillac</P></TD>
Escalade ESV</P></TD>
3G203193</P></TD>
3G219590</P></TD></TR>
<TR>
<TD vAlign=center align=middle rowSpan=4>
2003</P></TD>
Chevrolet</P></TD>
Silverado</P></TD>
31100076</P></TD>
31272767</P></TD></TR>
<TR>
3E104200</P></TD>
3E236298</P></TD></TR>
<TR>
3F100804</P></TD>
3F184501</P></TD></TR>
<TR>
3Z106886</P></TD>
3Z244282</P></TD></TR>
<TR>
2003</P></TD>
Chevrolet</P></TD>
Avalanche</P></TD>
3G101052</P></TD>
3G219648</P></TD></TR>
<TR>
<TD vAlign=center align=middle rowSpan=2>
2003</P></TD>
Chevrolet</P></TD>
Tahoe</P></TD>
3J101526</P></TD>
3J214306</P></TD></TR>
<TR>
3R102394</P></TD>
3R216747</P></TD></TR>
<TR>
<TD vAlign=center align=middle rowSpan=3>
2003</P></TD>
Chevrolet</P></TD>
Suburban</P></TD>
3G100209</P></TD>
3G219643</P></TD></TR>
<TR>
3J100715</P></TD>
3J214291</P></TD></TR>
<TR>
3R129888</P></TD>
3R216757</P></TD></TR>
<TR>
2003</P></TD>
GMC</P></TD>
Sierra</P></TD>
31100722</P></TD>
31272696</P></TD></TR>
<TR>
3E100639</P></TD>
3E236296</P></TD></TR>
<TR>
3F107734</P></TD>
3F194511</P></TD></TR>
<TR>
3Z102118</P></TD>
3Z244186</P></TD></TR>
<TR>
2003</P></TD>
GMC</P></TD>
Yukon</P></TD>
3J112259</P></TD>
3J214157</P></TD></TR>
<TR>
3R100174</P></TD>
3R216703</P></TD></TR>
<TR>
2003</P></TD>
GMC</P></TD>
Yukon XL</P></TD>
3G106714</P></TD>
3G219519</P></TD></TR>
<TR>
3J106804</P></TD>
3J214131</P></TD></TR>
<TR>
3R185288</P></TD>
3R216717</P></TD></TR>
<TR>
2003</P></TD>
HUMMER</P></TD>
H2</P></TD>
3H101507</P></TD>
3H124932</P></TD></TR></TBODY></TABLE>
<FONT color=brown>
<H4>Important</H4>
Dealers should confirm vehicle eligibility through GMVIS (GM Vehicle
Inquiry System) or GM Access Screen (Canada only) or DCS Screen
445
(IPC only) prior to beginning program repairs. [Not all vehicles within
the above breakpoints may be involved.]</P></FONT>
</P>
Involved vehicles have been identified by Vehicle Identification Number.
Computer listings containing the complete Vehicle Identification Number,
customer name and address data have been prepared, and are being furnished to
involved dealers with the program bulletin. The customer name and address data
furnished will enable dealers to follow up with customers involved in this
program. Any dealer not receiving a computer listing with the program bulletin
has no involved vehicles currently assigned. </P>
These dealer listings may contain customer names and addresses obtained from
Motor Vehicle Registration Records. The use of such motor vehicle registration
data for any other purpose is a violation of law in several
states/provinces/countries. Accordingly, you are urged to limit the use of this
listing to the follow-up necessary to complete this program. </P><A
name=ss4-1256458><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1256458&amp;psdid=293&amp;evc= sm#ss4-1256458">
<H5>Parts Information</A></H5>
No parts are required for this recall.</P><A name=ss5-1256458><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1256458&amp;psdid=293&amp;evc= sm#ss5-1256458">
<H5>Service Procedure</A></H5>
<FONT color=brown>
<H4>Important</H4>
The labor time for performing the refresh/reprogram of the passenger door
module in this recall is different than the amount of time allowed in Service
Bulletin03-08-52-001B. The labor operation code and time allowance in the
service bulletin was for a BCM reprogram, and was not the correct labor
operation code for this repair.</P></FONT>
</P>Inspection Procedure
</P>
<FONT color=brown>
<H4>Important</H4>
The following inspection must be performed in order to determine the correct
repair procedure.</P></FONT>
</P>
  1. <LI type=1>Turn the ignition to the ON position.
    <LI type=1>Using the switches in the right front passenger door, verify that
    the power window and power door lock located in that door, function properly.
    <UL type=BULLET>
    <LI>If the power window and door locks do NOT function, proceed to the
    "Refresh and Reprogram" procedure and follow ALL of the steps.
    <LI>If the power window and door lock function properly, the vehicle only
    needs to be updated with the new calibration for the passenger door module.
    Proceed to and follow only steps 4-6 in the "Refresh and Reprogram"
    procedure. DO NOT PERFORM STEPS 1-3. </LI>
</LI>[/list]Refresh and
Reprogram Procedure
</P>
<FONT color=brown>
<H4>Important</H4>
Steps 1-3 in the following procedure should only be performed if the power
window and door lock did NOT function properly in the inspection procedure
above.</P></FONT>
</P>
<FONT color=brown>
<H4>Important</H4>
In order to perform the following procedure, your Tech2 must be updated
with software version23.001 or later, CD#3. If your Tech2 does
not have the necessary software, it will need to be updated before
proceeding.</P></FONT>
</P>
  1. <LI type=1>Turn the ignition switch to the ON position.
    <LI type=1>Connect the Tech2 to the vehicle's diagnostic link connector
    (DLC), power it up and press enter.
    <UL type=BULLET>
    <LI>Select FO : Diagnostics
    <LI>Select Model Year 2003
    <LI>Select Light Duty (LD) Truck
    <LI>Select F1 : Body
    <LI>Select Product Line
    <LI>Select Type of Air Conditioning
    <LI>Select Type of Radio
    <LI>Scroll down as necessary and select "Passenger Door Module."
    <LI>Select F2: Special Functions
    <LI>Select F3: Refresh
    <LI>
    <FONT color=brown>
    <H4>Important</H4>
    You must remove the described fuse in the next step for the "Refresh"
    program to be performed. If you do not remove the fuse for five seconds, the
    Tech2 will continue to display "Test in Progress" and the program will
    not complete.</P></FONT>
    </P>Remove the PDM fuse for 5seconds from the fuse center located
    behind the panel on the left end of the instrument panel.
    <LI>Reinstall the fuse and fuse panel cover.
    <LI>Press the "Enter" button to perform the "Refresh" function.
    <LI>"Test in Progress" will be displayed and the right front passenger door
    lock will cycle once.
    <LI>The screen will display "Procedure Completed".
    <LI>Press the "Exit" button as necessary to return to the main menu screen.
    </LI>
<FONT color=brown>
<H4>Important</H4>
The calibrations required for performing SPS reprogram in the next step are
based on the type of exterior rearview mirror that the vehicle has. To
determine the correct calibration, check the Service Parts Identification
Label on the vehicle for the RPO code for the exterior mirrors.</P></FONT>
</P>
<LI type=1>Follow normal Service Programming System (SPS) to reprogram the
passenger door module with the new calibration.
<LI type=1>After reprogramming is complete, using the switches in the right
front passenger door, verify that the power window and power door lock located
<LI type=1>Install the GM Recall Identification Label. </LI>[/list]<A
name=ss6-1256458><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1256458&amp;psdid=293&amp;evc= sm#ss6-1256458">
<H5>Identification Label - For US and IPC</A></H5>
Place a Recall Identification Label on each vehicle corrected in accordance
with the instructions outlined in this Product Recall Bulletin. Each label
provides a space to include the recall number and the five (5) digit dealer code
of the dealer performing the recall service. This information may be inserted
with a typewriter or a ball point pen. </P>
Put the Recall Identification Label on a clean and dry surface of the
radiator core support in an area that will be visible to people servicing the
vehicle. When installing the Recall Identification Label, be sure to pull
the tab to allow the adhesion of the clear protective covering. Additional
Recall Identification Labels for US dealers can be obtained from Dealer Support
Materials by either ordering on the web from DWD Store, gm-dealerworld.com, or
calling 1-866-700-0001 (Monday-Friday, 8:00am to 5:00pm EST). Ask
for Item Number S-1015 when ordering.
</P>
Additional Recall Identification Labels for IPC dealers can be obtained
from your Regional Marketing Office.
</P><A name=ss7-1256458><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1256458&amp;psdid=293&amp;evc= sm#ss7-1256458">
<H5>Identification Label - For Canada</A></H5>
Place a Program Identification Label on each vehicle corrected in accordance
with the instructions outlined in this Product Program Bulletin. Each label
provides a space to include the program number and the five (5) digit dealer
code of the dealer performing the program service. This information may be
inserted with a typewriter or a ball point pen. </P>
Put the Program Identification Label on a clean and dry surface of the
vehicle. Additional Program Identification Labels for Canadian dealers can
be obtained from DGN by calling 1-800-668-5539 (Monday-Friday, 8:00am to
5:00pm EST). Ask for Item Number GMP91 when ordering.
</P><A
name=ss8-1256458><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1256458&amp;psdid=293&amp;evc= sm#ss8-1256458">
<H5>Courtesy Transportation</A></H5>
The General Motors Courtesy Transportation program is intended to minimize
customer inconvenience when a vehicle requires a repair that is covered by the
New Vehicle Limited Warranty. The availability of courtesy transportation to
customers whose vehicles are within the warranty coverage period and involved in
a product recall is very important in maintaining customer satisfaction. Dealers
are to ensure that these customers understand that shuttle service or some other
form of courtesy transportation is available and will be provided at no charge.
Dealers should refer to the General Motors Service Policies and Procedures
Manual for Courtesy Transportation guidelines.</P><A name=ss9-1256458><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1256458&amp;psdid=293&amp;evc= sm#ss9-1256458">
<H5>Claim Information</A></H5>
Submit a Product Program Claim with the information indicated below. </P>
<TBODY>
<TR>
Repair Performed</P></TH>
Part Count</P></TH>
Part No.</P></TH>
Parts Allow</P></TH>
CC-FC</P></TH>
Labor Op</P></TH>
Labor Hours*</P></TH></TR>
<TR>
<TD vAlign=center align=left>
Reprogram PDM (Inc. Refresh, if necessary)</P></TD>
0</P></TD>
N/A</P></TD>
N/A</P></TD>
MA-96</P></TD>
V0987</P></TD>
0.3</P></TD></TR>
<TR>
Courtesy Transportation</P></TD>
N/A</P></TD>
N/A</P></TD>
N/A</P></TD>
MA-96</P></TD>
**</P></TD>
N/A</P></TD></TR>
<TR>
<TD vAlign=center align=left colSpan=7>
* -- For Program Administrative Allowance, add 0.1 hours to the "Labor
Hours".</P>
** -- Submit courtesy transportation using normal labor operations for
courtesy transportation as indicated in the GM Service Policies and
Procedures Manual.</P></TD></TR></TBODY></TABLE>
Refer to the General Motors WINS Claim Processing Manual for details on
Product Recall Claim Submission.</P><A name=ss10-1256458><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1256458&amp;psdid=293&amp;evc= sm#ss10-1256458">
<H5>Customer Notification -- For US and Canada</A></H5>
Customers will be notified of this program on their vehicles by General
Motors (see copy of customer letter included with this bulletin). </P><A
name=ss11-1256458><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1256458&amp;psdid=293&amp;evc= sm#ss11-1256458">
<H5>Customer Notification -- For IPC</A></H5>
Letters will be sent to known owners of record located within areas covered
by the US National Traffic and Motor Vehicle Safety Act. For owners outside
these areas, dealers should notify customers using the attached suggested dealer
letter.</P><A name=ss12-1256458><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1256458&amp;psdid=293&amp;evc= sm#ss12-1256458">
<H5>Dealer Program Responsibility -- ALL</A></H5>
All unsold new vehicles in dealers' possession and subject to this program
MUST be held and inspected/repaired per the service procedure of this program
bulletin BEFORE customers take possession of these vehicles.</P>
Dealers are to service all vehicles subject to this program at no charge to
customers, regardless of mileage, age of vehicle, or ownership, from this time
forward.</P>
Customers who have recently purchased vehicles sold from your vehicle
inventory, and for which there is no customer information indicated on the
dealer listing, are to be contacted by the dealer. Arrangements are to be made
to make the required correction according to the instructions contained in this
bulletin. This could be done by mailing to such customers a copy of the customer
letter accompanying this bulletin. Program follow-up cards should not be used
for this purpose, since the customer may not as yet have received the
notification letter.</P>
In summary, whenever a vehicle subject to this program enters your vehicle
inventory, or is in your dealership for service in the future, you must take the
steps necessary to be sure the program correction has been made before selling
or releasing the vehicle.</P>March, 2003
Dear General Motors Customer:</P>
We want your experience owning your 2003 model year Cadillac Escalade,
Escalade EXT, or Escalade ESV; Chevrolet Silverado, Avalanche, Tahoe, or
Suburban; GMC Sierra, Yukon, or Yukon XL; or HUMMER H2 to be better than any
other you've had ... which is why we're writing.</P>
We have learned that on your 2003 model year Cadillac Escalade, Escalade EXT,
or Escalade ESV; Chevrolet Silverado, Avalanche, Tahoe, or Suburban; GMC Sierra,
Yukon, or Yukon XL; or HUMMER H2, the Passenger Door Module (PDM) may become
keyless entry, front passenger power window, lock, mirror, and heated seat
functions.</P><A name=ss13-1256458><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1256458&amp;psdid=293&amp;evc= sm#ss13-1256458">
<H5>What We Have Done</A></H5>
We've sent your GM dealer new calibrations to reprogram the PDM, which will
eliminate this condition. This reprogramming will be performed for you at no
charge
.</P><A name=ss14-1256458><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1256458&amp;psdid=293&amp;evc= sm#ss14-1256458">
<H5>What You Should Do</A></H5>
We recommend that you contact your GM dealer to arrange a service date.</P><A
name=ss15-1256458><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1256458&amp;psdid=293&amp;evc= sm#ss15-1256458">
<H5>Customer Reply Card</A></H5>
Presenting the attached card to your dealer will assist in making the
necessary correction in the shortest possible time.</P>
If you no longer own this vehicle, please check the appropriate box and
provide new owner information, if available.</P>
If you have any questions or need any assistance, just contact your dealer or
the appropriate Customer Assistance Center at the number listed below:</P>
<TBODY>
<TR>
Division</P></TH>
Number</P></TH>
Deaf, Hearing Impaired, or Speech Impaired*</P></TH></TR>
<TR>
Cadillac</P></TD>
1-800-458-8006</P></TD>
1-800-833-2622</P></TD></TR>
<TR>
Chevrolet</P></TD>
1-800-222-1020</P></TD>
1-800-833-2438</P></TD></TR>
<TR>
GMC</P></TD>
1-800-462-8782</P></TD>
1-800-462-8583</P></TD></TR>
<TR>
HUMMER</P></TD>
1-866-486-6376</P></TD>
</P></TD></TR>
<TR>
Puerto Rico - English</P></TD>
1-800-496-9992</P></TD>
</P></TD></TR>
<TR>
Puerto Rico - Español</P></TD>
1-800-496-9993</P></TD>
</P></TD></TR>
<TR>
Virgin Islands</P></TD>
1-800-496-9994</P></TD>
</P></TD></TR>
<TR>
<TD vAlign=center align=left colSpan=3>
* Utilizes Telecommunication Devices for the Deaf/Text Telephones
(TDD/TTY)</P></TD></TR></TBODY></TABLE>
If your vehicle is within the New Vehicle Limited Warranty your dealer may
provide you with shuttle service or some other form of courtesy transportation
while your vehicle is at the dealership for this repair. Please refer to your
Owner's Manual and your dealer for details on Courtesy Transportation.</P>
We sincerely regret any inconvenience this causes you. Also, we want you to
know that we will continue to do everything we can to ensure that you are
completely satisfied with our products</P>
General Motors Corporation</P>
Enclosure</P>
</P>
<TBODY>
<TR>
the information.
</FONT></TD>
CERTIFICATION
Reserved.
</P>
<HR>
<TBODY>
<TR>
2003 HUMMER
H2
</TD>
Old 03-02-2004, 01:58 AM
Thanks Klaus.
I asked the service writer to check for any TSB's. I think I will print this out and take it to him.
Any on an inoperative horn? I have had intermittent problems since I bought it.
Thanks again.
Old 03-03-2004, 10:30 PM
Klaus's Avatar
<TBODY>
<TR>
<TD align=middle width="50%">Document ID# 644920
2003 HUMMER
H2
</TD>
<HR>
</FORM>
<H1>Horns Inoperative</H1><A name=ss1-644920><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=644920&amp;psdid=293&amp;evc=s m#ss1-644920">
<H5>Test Description</A></H5>
The numbers below refer to the step numbers on the diagnostic table.</P>
  1. <A name=TD04>
    <LI value=4>
    Verifies that the body control module (BCM) is providing ground to the horn
    relay.</P><A name=TD05>
    <LI value=5>
    Tests for voltage at the battery positive voltage terminal of the horn
    relay coil.</P><A name=TD07>
    <LI value=7>
    relay switch. The HORN fuse supplies power to the battery positive voltage
    terminal of the horn relay switch.</P><A name=TD13>
    <LI value=13>
    The horns need maximum current flow to operate properly. A high resistance
    (greater than 0.5ohms) in the horn control circuit or the horn ground
    circuit could cause operating problems with the horns. Inspect the circuits
    for faults that would restrict current flow.</P><A name=TD15>
    <LI value=15>
    The horn relay control circuit includes the horn switch. The horn switch
    must be tested for a high resistance, an open or a short to voltage when
    testing the relay control circuit. </P></LI>
<TBODY>
<TR>
<TH vAlign=center align=middle>
Step</P></TH>
Action</P></TH>
Yes</P></TH>
No</P></TH></TR>
<TR>
1</P></A></TD>
Did you perform the Horns Diagnostic System Check?</P></TD>
Go to Step2
</P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=48491&amp;RefDoc=644920">Diagno stic
System Check - Horns</A> </P></TD></TR>
<TR>
2</P></A></TD>
Depress the horn switch.</P>
Do the horns operate?</P></TD>
Go to Step3
</P></TD>
Go to Step5
</P></TD></TR>
<TR>
3</P></A></TD>
    <LI type=1>With a scan tool, command the body control module (BCM) Horn
    Output ON and OFF. </LI>
Go to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=62112&amp;RefDoc=644920">Testin g
Go to Step4
</P></TD></TR>
<TR>
4
</P></A></TD>
Test the BCM portion of the horn relay control circuit for a high
resistance or an open. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=62194&amp;RefDoc=644920">Circui t
Testing</A> and <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=61965&amp;RefDoc=644920">Wiring
Go to Step21
</P></TD>
Go to Step11
</P></TD></TR>
<TR>
5
</P></A></TD>
    <LI type=1>Disconnect the horn relay.
    <LI type=1>Connect a test lamp between the battery positive voltage
    circuit of the horn relay coil and a good ground. </LI>
Go to Step6
</P></TD>
Go to Step14
</P></TD></TR>
<TR>
6</P></A></TD>
  1. <LI type=1>Connect a test lamp between the battery positive voltage
    circuit of the horn relay coil and the horn relay control circuit.
    <LI type=1>Depress and hold the horn switch. </LI>
Go to Step7
</P></TD>
Go to Step15
</P></TD></TR>
<TR>
7
</P></A></TD>
Connect a test lamp between the battery positive voltage circuit of the
horn relay switch and a good ground.</P>
Go to Step8
</P></TD>
Go to Step16
</P></TD></TR>
<TR>
8</P></A></TD>
Momentarily connect a 15 amp fused jumper wire between the battery
positive voltage circuit of the horn relay switch and the horn control
circuit.</P>
Go to Step12
</P></TD>
Go to Step9
</P></TD></TR>
<TR>
9</P></A></TD>
  1. <LI type=1>Reconnect the horn relay.
    <LI type=1>Disconnect either horn connector.
    <LI type=1>Connect a test lamp between the horn control circuit and a
    good ground.
Go to Step10
</P></TD>
Go to Step17
</P></TD></TR>
<TR>
10</P></A></TD>
  1. <LI type=1>Connect a test lamp between the horn control circuit and the
    horn ground circuit.
Go to Step13
</P></TD>
Go to Step18
</P></TD></TR>
<TR>
11</P></A></TD>
to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=61973&amp;RefDoc=644920">Connec tor
Go to Step21
</P></TD>
Go to Step19
</P></TD></TR>
<TR>
12</P></A></TD>
Inspect for poor connections at the horn relay. Refer to <A
Go to Step21
</P></TD>
Go to Step20
</P></TD></TR>
<TR>
13
</P></A></TD>
Repair the high resistance in the horn control circuit or the horn
ground circuit. Also, though unlikely, it is possible that both horns are
defective. Refer to <A
Testing</A> and <A
Go to Step21
</P></TD>
--</P></TD></TR>
<TR>
14</P></A></TD>
Repair the open or high resistance in the battery positive voltage
circuit of the horn relay coil. Refer to <A
Testing</A> and <A
Go to Step21
</P></TD>
--</P></TD></TR>
<TR>
15
</P></A></TD>
Repair the open or short to voltage in the horn relay control circuit.
The horn relay control circuit includes the horn switch. Refer to <A
Testing</A> and <A
Go to Step21
</P></TD>
--</P></TD></TR>
<TR>
16</P></A></TD>
circuit of the horn relay switch. Refer to <A
Testing</A> and <A
Go to Step21
</P></TD>
--</P></TD></TR>
<TR>
17</P></A></TD>
Repair the open or high resistance in the horn control circuit. Refer
to <A
Testing</A> and <A
Go to Step21
</P></TD>
--</P></TD></TR>
<TR>
18</P></A></TD>
Repair the open or high resistance in the horn ground circuit. Refer to
<A
Testing</A> and <A
Go to Step21
</P></TD>
--</P></TD></TR>
<TR>
19</P></A></TD>
<FONT color=brown>
<H4>Important</H4>
Perform the BCM programming procedure when replacing the
BCM.</P></FONT>
</P>
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=9004&amp;RefDoc=644920">Body
Control Module Replacement</A> in Body Control System.</P>
Go to Step21
</P></TD>
--</P></TD></TR>
<TR>
20</P></A></TD>
Replace the horn relay.</P>
Go to Step21
</P></TD>
--</P></TD></TR>
<TR>
21</P></A></TD>
Operate the horns.</P>
Do the horns operate properly?</P></TD>
System OK</P></TD>
Go to Step1
<HR>
<TBODY>
<TR>
2003 HUMMER
H2
</TD>
<TD align=right width="25%"></TD></TR></TBODY></TABLE></FORM></A></BODY></HTML>
Old 03-04-2004, 01:01 AM
Thanks again Klaus.
