Old 08-31-2004, 03:58 AM
HummerKing HummerKing is offline
HummerKing is off the scale
Hi, I was wondering how to remove those roof rack bars on top of the Hummer? It first seems so easy by just unscrewing the thing and slide down to the end of the top and take it out. But at the end of it, there's a lock thingy.. and I have no idea how to take it out. Any pointers?
Old 08-31-2004, 04:17 AM
You must remove the plastic "thingy" at the rear of the rails. I used a medium flat blade screw driver to pry them up. As you gently do this you will see where the grabbing points are for the end piece. Use care with these as they are easy to break.
The dealership told me to "just pull harder" on them. They were right.
Old 08-31-2004, 04:25 AM
Thanks KenP. I tried that as I found some threads about it (after I posted my question) but i was afraid I'd break it. I pry it up then stick my finger into that hole and pull it up... but it never got off.. until i gave up.
Maybe I should "pull it a little harder".
Old 08-31-2004, 04:37 PM
HummerLV's Avatar
HummerLV HummerLV is offline
HummerLV is off the scale
yes pull harder seems like too much pulling but they will POP off
Old 05-03-2005, 08:06 PM
VTSTOMPER is off the scale
Anyone know if the SUT is the same? Or do I have to remove the steel channel they slide though? I have running lights pretty much at both ends.
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 05-03-2005, 08:30 PM
To answer my own question:
Take the rear marker light off...then there are two small torq head bolts, remove those and press on the small tab that is holding the peice to the channel system. Do the same to the other side, and move them out of the way. Slide the bars all the way back evenly. Boom - done.
Old 05-05-2005, 12:39 AM
Take the rear marker light off...then there are two small torq head bolts, remove those and press on the small tab that is holding the peice to the channel system. Do the same to the other side, and move them out of the way. Slide the bars all the way back evenly. Boom - done. </div></BLOCKQUOTE>
...and last step, replace factory crossbars with Gobi rack.
Old 05-06-2005, 08:01 AM
tower's Avatar
tower tower is offline
Yes, and DO replace the rear marker lights.
Old 05-09-2005, 03:12 PM
joejoe1 joejoe1 is offline
joejoe1 is off the scale
I have a regular 03 H2 ... do I need to remove the rear lights? I tried pulling on the little channel thing too and it seems if I pull too hard it will break. I tried unscrewing the torque head bolt in the little hole and that thing is on really tight.
Old 05-09-2005, 06:52 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by tower:
Yes, and DO replace the rear marker lights. </div></BLOCKQUOTE>
ROFL! I should have added that!
Old 05-10-2005, 12:06 AM
tower's Avatar
JoeJoe1,
Just pull it!
http://elcova.com/groupee/forums/a/t...511#5961078511
Old 05-11-2005, 04:05 PM
tower's Avatar
And no, on an '03 (or any SUV) you don't need to remove any marker lights to remove the roof racks.
