Old 06-16-2005, 11:18 AM
TXSUT's Avatar
TXSUT TXSUT is offline
Nitto Mud Grapplers in 37x13.5x18 mounted on 18x10 Weld wheels with 4.5 inch offset...the outer edge of the tire does rub pretty hard on the fender well when turning. No obvious rubbing anywhere else while on-road.
Before I start hacking away at the plastic, I'm going to see if I can get enough height out of the torsion bars to eliminate the rubbing.
Just thought this might be useful info in case anyone was considering a similar installation.
-Pete
