Old 01-10-2006, 09:01 PM
FishnMan's Avatar
FishnMan FishnMan is offline
FishnMan is off the scale
OK, here’s the deal. I replaced the dull stock headlight and fog bulbs with these bulbs purchased at automotivelightingusa.com
H13 Luminics Ultra White 5150K 50/55W
H10 Nokya Hyper Yellow 2500K 45/55W
Lights were replaced by the dealer as my H3 won’t fit into my garage. First time in, the tech did not align them (at all)…wtf? When I turned on lights they were all over the place and it looked like I had no lights all ……BAD! So, I took it back the next day. Second time in, headlights now aligned but fogs still kinda F’d up. Geez, if they can’t even put bulbs in right, should I let them do my scheduled maint/repairs? Hmmmmm!
So, my humble opinion: Together (heads and fogs on) the visibility is really pretty good and it looks good too. The headlights are very white looking with a slight tint of blue. The fogs are very yellow and cut through the fog/haze/darkness quite nicely! I highly recommend these H10 Nokya Hyper Yellow bulbs. However, when I switch to high beam (fogs automatically turn off), it looks pretty dim. Not good!!! These Luminics H13 bulbs are not very penetrating and I would not recommend unless you want to just look good, not see good! Had better visibility with stock high beam lights! So, except for high beams, which I don’t really need with heads and fogs on together, these lights will do until summer (when it doesn’t get dark here! lol). So, it’s wait for another H13 bulb option or break the bank for HIDs; I have about 9 months to make up my mind, then it gets dark again.
Fishin is the Mission!
