02-14-2004, 07:48 PM
I just purchased a Viair 450c compressor for my H2. I was wondering where some of you have mounted your compressors. Pictures would be great. Thanks.
02-15-2004, 12:14 AM
Did you get a storge tank too? Just wondering.
02-15-2004, 10:04 AM
Not yet I want to see how it is airing up my tires first. If it is too slow and I can find somewhere to mount the tank then I will get one.
02-15-2004, 10:29 PM
I mounted my storage tank and air compressor under the truck on the frame. It's for my air horns but it should be similar setup.
02-18-2004, 12:13 AM
i mounted a 14 inch tank under my rear bumper...
A TANK IS A MUST!!! especially a bigger one. it makes the airing up a breeze... plus then you can install some front and rear quick disconnects and use any air powertool you want..
unaslob
02-18-2004, 09:58 AM
Unaslob thanks for the reply,do you have any more pictures of your install? Where is your compressor mounted? And where did you buy your tank?
02-19-2004, 12:27 AM
i will get some pics of the compressor install. I installed it the same place the realwheels compressor goes.. in fact i got the same compresssor.. realwheels will not sell you the compressor without the horn. the ppl that make the compressor and a number of great horns. there is a company called component parts. they sell hadley stuff separately.. they also sell the airlines and valves and what ever you would need.
will take the F$king heavy winch off to get you some nice pics of the compressor.. plus will get some better pics of the tank...lanyard...ect
unaslob
02-19-2004, 01:50 AM
UNASLOB, can you use your compresson to dry the Hummer after a carwash (or heavy rain)? I noticed that the "handwash" carwash in my area are using compressed air to push water especially in nooks & crannies of the car.
04 Pewter
