03-22-2005, 03:34 PM
Hello.
I am new in the forum.I am of Spain.
my ingles is not very good, pardon.
I want to you to make a consultation.
¿They exist to Hummer H2 with Diesel engine or in future they made it?
Thanks for the aid
Hello.
Thanks for the aid
03-22-2005, 03:40 PM
Rumor said that some time in the future...2007 or so. Rumor also said that it might be in the 2006 H3 or 2007 H3.
(EDIT) What sfox said!
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
03-22-2005, 04:52 PM
Bienvenidos Makoatt,
Cuando compré mis 2003 H2, el GM me dijo que un diesel estuviera disponible en 2006. También dijeron que requeriría un cambio en el chasis para acomodar la transmisión del alyson que el diesel utiliza. No he oído cualquier cosa desde entonces, pero hasta que oigo algo oficial del GM, asumiría que no se planea ninguna producción diesel para el H2.
Que le vaya bien,
torre
03-22-2005, 04:59 PM
The way I've heard it is 2007 H2 Alpha will be a diesel. Could be completely off, but thats what I'm going with right now.
03-23-2005, 03:45 PM
This is the answer of GM to my e-mail.
Thank you for contacting HUMMER and for your interest in the HUMMER H2! There are many factors that influence the production of a model line. Availability of materials and customer demand influences the rate of production as well as cost. HUMMER reserves the right to make changes at any time, without notice, in prices, colors, materials, equipment specifications, models and availability.
The HUMMER H2 does not offer a diesel engine and there are no plans at this time to add it to the portfolio. A standard already exists for the Duramax Diesel. The Duramax Diesel and Allison transmission do not fit in the engine compartment of the H2 and would need to be redesigned to accommodate the engine and radiator. However, the HUMMER H1 does offer a diesel engine.
The HUMMER H2 features a Vortec 6000 High Output V8 and heavy-duty 4L65-E four-speed automatic transmission with overdrive, offering the best-in-class power and performance! The Vortec 6000 pumps 316 horsepower at 5200 rpm and 360 lb.-ft of torque at 4000, capable of out-muscling and out-torquing H2's premium off-road competitors. A standard 4.10 axle ratio, combined with the transmission's deep first-gear ratio and transfer case low-range gear reduction, provides an excellent 33:1 crawl ratio for very slow, controlled, high-torque rock and obstacle climbing capability. The top speed of the H2 is 96 mph (miles per hour).
Sincerely,
Jack Chance
HUMMER
Customer Relationship Manager
03-23-2005, 03:54 PM
¿That he is Duramax Diesel?
In Spain Hummer H2 is newness and people are fascinated by her dimensions and consumption.
Thanks for your answers.
03-23-2005, 03:57 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by MAKOATT:
The Vortec 6000 pumps 316 horsepower </div></BLOCKQUOTE>
Wow someone at GM needs to change their pre written responses
