04-26-2006, 11:41 PM
when i installed the k%n cold air intake i disconnected the battery via the instructions that came with k%n , i previously re-programmed the truck with hyper-tech, when i disconnnected the battery did i re-set the factory computer to "cancel" the hypertech program i installed?
04-27-2006, 12:27 AM
No you did not. The factory program is inside your hypertech right now. You can always check by plugging back in the hypertech and it will display "programming installed" Its all good
04-27-2006, 12:52 AM
THANKS, i just read an earlier post saying something about when the battery is unhooked and placed back , it automatically resets to the factory settings
04-27-2006, 12:57 AM
just quit, walk away and quit
04-27-2006, 01:34 AM
hey paragon , what did i tell you about typing while my dikk is in your mouth?
04-27-2006, 01:42 AM
duh huh
04-27-2006, 03:39 AM
ECMs contain a base Air/Fuel & timing table stored in the ECMs ROM. It will be there even if power is removed. It doesn't matter if this is the OEM map or one from Hypertech.
There is also some AFR customization that occurs depending on data the ECM received from sensors (MAF, O2, TP sensor etc.). This is what gets reset after disconnecting the battery. This is needed to compensate for dynamic variables because every engine is different and experiences numerous changes throughout it's lifespan.
04-27-2006, 03:50 AM
Your homoerotic fantasies are creepy. Keep 'em to yerself, k?
04-28-2006, 11:22 PM
U ARE NOT WORTHY OF A CHUCK NORRIS AVATR, GO HOME
04-28-2006, 11:44 PM
Are you worthy of the nothingness you have for an avatar?
04-29-2006, 01:48 AM
UR UP PARAGONS ASS TOO?
04-29-2006, 02:03 AM
Yuz an idiot. Why iz ya even up in chere? If yuz can'ts work das shiat jus chunk it. Aight?
04-29-2006, 02:13 PM
DUH HUH, is that a pic of u in ur avtr? how gay is ur pic?
04-29-2006, 02:40 PM
Lets look at Monstermatt for a moment,
Screen Name - Monstermatt - Matt is a Monster
Drives a ficticious H2- a big truck
I guessing this guy is trying hard to over compensate and has homoerotic fantisies of men Paragon in paticular.
This guy is probably about 5'2"- 5'3" 115-135 soaking wet, lacked a father figure and probably was picked on in his early teens and still shunned by females till this day. This is was causes his rage and attatchment to males in the mid 30's to upper 40's he just wants a daddy!
04-30-2006, 12:36 AM
NICE PROFILE, GEEK
04-30-2006, 05:10 AM
Yeah, it is about realistic as you being heterosexual and owning a hummer. Go away kid, go find your daddy!!
04-30-2006, 05:15 AM
Is this profile better????
05-01-2006, 12:54 AM
TOOL!!
05-01-2006, 06:47 PM
Aw come on dawg, Dont be hatin
05-02-2006, 12:26 AM
IF U WANNA DISH IT OUT , BE READY TO TAKE IT!! that goes for paragon too
