Old 11-05-2005, 10:49 PM
Lucci Lucci is offline
Lucci is off the scale
Does anyone "miss" the feature that it seems most keyless entry cars have: That when you unlock the car with the FOB; some of the front lights, backup lights and interior lights stay on for a specified amount of time or until you open the door? Can this be retrofitted from the H2 or is there someway to do this without too much hassle?
Old 11-05-2005, 11:23 PM
kodiakz kodiakz is offline
kodiakz is off the scale
Check you owners manual as I believe that function is programmable through either the radio controls or steering wheel controls.
Old 11-06-2005, 02:46 PM
Only four settings offered on the H3:
"RFA 1 (default): This mode flashes the parking lamps when you press the lock or unlock buttons on the remote keyless entry transmitter.
RFA 2: This mode flashes the parking lamps and sounds the horn when you press the lock button on the remote keyless entry transmitter. This mode also flashes the parking lamps when you press the unlock button on the remote keyless entry transmitter.
RFA 3: This mode flashes the parking lamps and sounds the horn when you press the lock or unlock buttons on the remote keyless entry transmitter.
RFA 4: This mode disables remote keyless entry feedback. There will be no feedback when you press the lock or unlock buttons on the remote keyless entry transmitter."
It is a function of the BCM and if the BCM does not offer turning on the lights, then it can't be done. In addition, you cannot install a H2 BCM into a H3.
Old 11-10-2005, 04:00 AM
WPBGUY WPBGUY is offline
WPBGUY is off the scale
When I took my H3 in for service. They gave me an H2. I noticed that the headlights stay on much longer than the H3. I was wondering if there is a way to set the timer?
