Old 10-29-2003, 04:19 AM
John D John D is offline
John D is off the scale
Velcro dot, one half on back key fob 2nd on steering column. About .99 cents at WalMart. Used the same fix on my old Suburu WRX, now i will do same on the H2 as soon as I find or buy the dots.
John D. 03 H2 being pulled behind 02 Royale XLII (know as a Toad in the RV world)
Old 10-29-2003, 01:40 PM
Already used your suggestion Phil and it worked just as you described.
Black Lingenfelter Lux
Old 10-29-2003, 11:11 PM
Jigga Jigga is offline
Jigga is off the scale
just flip the key ring back over the key when it's in the ignition and it won't be able to knock around.
2003 Pewter H2 with Adventure Package.
Go Auburn, War Eagle!
Sig lines are overrated.
Old 11-01-2003, 03:43 AM
just turn up the volume on the CD player really loud and you'll never notice it. Driving in silence sucks, you start to notice all the annoying noises your H2 makes
Old 11-02-2003, 12:36 AM
Frank Hewitt Frank Hewitt is offline
Frank Hewitt is off the scale
get a little key-chain caribiner and a few extra key rings for other keys. Once you put you key in the ignition and start it, simply clip the other keys off and set them in a cup-holder.
gasman
gasman
