Old 09-13-2003, 02:19 PM
H2-T2 H2-T2 is offline
H2-T2 is off the scale
A friend just called me with this problem:
Battery in his H2 went dead...recharged battery, now key is stuck in ignition because it will not return to the "off" position. Also, will not start. Any ideas? Thanks, Gary (H2-T2)
Old 12-03-2005, 05:39 PM
Ray West Ray West is offline
Ray West is off the scale
Key stuck in the 2003 H2 yesterday. Would turn to ACC or IGN and start but would not go past ACC to remove. Tried procedures on this list to no solution. Saw one post on the wiring under the cup holder and went after it. 6-wire connector on the side of the shifter under the cup holder had one broken wire (the yellow one). Took apart and soldered and problem is fixed. Thanks to the group for the lead. GMC wanted to replace the key switch for $350 and that wasn't even the problem...
Thanks,
Ray
2003 H2
Old 12-06-2005, 09:07 PM
ryanh2 ryanh2 is offline
ryanh2 is off the scale
What is the proper procedure for removing the cupholder to gain access to the wires? Thanks
Old 12-07-2005, 11:42 AM
Hummertech is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by xonxoff:
I'm on my second switch. I had a problem where my transmission would not shift. they said it was a problem with one of the power leads on the switch. Now i have a problem where the radio won't shut off all the time when I take out the key. I think they might have some bad switches out there. I am taking it in next week for another one </div></BLOCKQUOTE>
I would say they didn't time your ignition switch right.
To see if you have a broken wire by the shifter take the torx screw out of the front of shifter handle and lift up. then with a small flat blade screwdriver, just pop the shifter plate up. Then look at the connector for the shifter, the wires usually break right by the connector. Although your problem has a 30 to 1 chance of being a battery or ignition switch problem first.
Old 01-24-2005, 07:45 PM
Anthony33 Anthony33 is offline
Anthony33 is an unknown quantity at this point
Took it in and same sitution as Fever. All is better now
\'07 Black 2500 Dodge Ram SL
\'03 Black Hummer H2 Lux Series
Old 09-14-2003, 04:10 PM
Kevin B Kevin B is offline
Kevin B is off the scale
H2-T2, Please let me know if HM's fix worked, or if you got it out another way. Oh, do tell
Old 12-04-2005, 03:50 AM
Hummer Guy's Avatar
Hummer Guy is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by ARH1956:
There is an easy way to temporarily solve this problem if faced with it without any tools. Grab the plastic cover on the bottom of the steering column under the the key & yank it down from the rear,(side closest to front of H2). When it is removed you'll see a plunger, (metal cylinder about 3/8" in dia.) under the key cylinder. Push the plunger upward & pull the key out. This can be done until you are able to repair the broken wire on the shifter interface. </div></BLOCKQUOTE>
Cool -- thanks for the tip!
-Brian
http://www.hummerguy.net
Old 12-06-2005, 09:40 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by ryanh2:
What is the proper procedure for removing the cupholder to gain access to the wires? Thanks </div></BLOCKQUOTE>Pull... Oh wait. Take a small allen wrench and remove the shifter handle and then PULL. The cupholder panel is just held in place by clips.
Old 12-03-2005, 06:12 PM
VTSTOMPER is off the scale
Welcome to the forum Ray!
Glad the forum helped out!
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 09-13-2003, 04:06 PM
Thanks Adam...I am sure that the battery is fully charged. Any idea what fuses were blown in your vehicle? I would hate to see it flat bedded all the way back to the dealer on Monday.
Gary (H2-T2)
Old 12-03-2005, 06:27 PM
Hummer Guy's Avatar
I was never a fan of the key locking itself in if you have a dead battery. What if you had a dead battery in a parking lot and needed to leave and didn't have a spare key handy? Anyone who had jump cables now has a free hummer...
-Brian
Old 12-06-2005, 09:33 PM
Kellen's Avatar
Kellen Kellen is offline
Kellen is an unknown quantity at this point
I know a guy who played hockey without a cup. Not good.
Old 01-21-2005, 08:29 AM
Hi Hummerman
I followed those steps and NO luck Im sure Im doing something wrong.
All is good, my battery life seems strong. My 2003 H2 has 29k on it, and today I got in, drove two blocks. It was about 18 degrees here in Chicago. When I arrived to my destination, I tried to pull the key out it was stuck. I called onstar, and they connected me to a Hummer service rep and she had no idea about my problem nor ever heard of this. After reading the board. I see I'm NOT the ONLY one that experianced this.
I am able to start the H2, turn it off, but the dash lights stay on. I disconnected the battery for the moment.
Anyone with advice please help. I will call around later today between business hours and see if anyone at the hummer dealerships can help.
thank you
Anthony
Old 09-14-2003, 05:55 PM
Props to H.M. Good job.
Old 01-22-2005, 03:07 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Remove center console cupholders and check wiring at 4 wire connector on switch, may have one or more broken wires there if so repair and extend harness to allow more travel when shifting gears.
1998 Chev Z71
2007 Chev Trailblazer SS
Old 09-14-2003, 04:48 PM
Hummer Man!!!! you are the H2-GURU.. We followed your instructions, and, low and behold, truck started...key came out...saved a flat-bed trip to dealer. I recommend everyone print Hummer Man's magic formula, in case your key gets stuck...Thank you, Thank you...Gary (H2-T2)
Old 12-03-2005, 11:48 PM
ARH1956 ARH1956 is offline
ARH1956 is off the scale
Old 09-13-2003, 03:17 PM
Gary, I had a problem like this as a result of some blown mega fuses. I think it's a theft deterrent issue and he will need a new battery, or at least a jump.
Adam P. Smith
Mortgage Pros, Inc.
303-407-2405 p
303-407-2414 f
aps101374@yahoo.com
Old 09-14-2003, 03:35 PM
Hummer Man is off the scale
DO THESE IN ORDER TO UN STICK KEY!!!
CHECK THE BRAKE FUSE
CHARGE THE BATTERY
PUT THE EMERGENCY BRAKE ON
ROTATE THE KEY TO ACCESSORY POSISTION
CLOSE THE DOOR
ROTATE KEY TO IGNITION POSOTION
DEPRESS FOOT BRAKE
RELEASE EMERGENCY BRAKE
START VEHICLE
