Old 01-23-2006, 07:57 PM
#06-08-44-001 Ticking Noise From Radio Speakers (Check for DTCs and Replace Radio, If necessary) - (Jan 4, 2006)
#05-08-46-001A OnStar Generation-6 (Digital) System Inoperative/Has No Power, LED Light Not On (Remove/Reinstall OnStar Fuse and Replace VCIM or Follow SI Diagnostics) - (Jan 4, 2006)
#05-03-10-003A Low Tire Pressure Leaking Cast Aluminum Wheels (Repair with Adhesive Sealant) - (Dec 19, 2005)
#05-08-64-002A Door Latch Freezing In Cold Temperatures (Apply Super Lube) - (Dec 19, 2005)
#05-08-51-008 Bumps or Rust Colored Spots in Paint Due to Rail or Iron Dust (Remove Rail Dust) - (Nov 22, 2005)
#05-08-42-017 Tail Lamp Housing Separates from Tail Lamp Retainers (Replace Tail Lamp Housing Retainers) - (Nov 11, 2005)
#01-07-30-038C Diagnostic Trouble Code (DTC) P0757 Set, Service Engine (SES) Lamp Illuminated, Poor Performance of Transmission, Transmission Slipping (Clean Transmission Valve Body and Case Oil Passages of Debris) - (Oct 12, 2005)
#05-08-66-006 Door Ajar Lamp On, Chimes Sound or Door Locks Cycle While Driving (Adjust Swing Gate Striker) - (Oct 11, 2005)
#01-07-30-002E Malfunction Indicator Lamp (MIL) On, Transmission Stuck in Second or Third Gear, Instrument Cluster Inoperative (Verify and Repair Source of Voltage Loss in Transmission Solenoid Power Supply Circuit) - (Sep 23, 2005)
#05-08-51-005 Cloudy Spot in Paint After Protective Covering is Removed (Heat Area) - (Sep 21, 2005)
#05-04-21-006 Service Four Wheel Drive (4WD) Light On, Diagnostic Trouble Codes (DTC) B0790, B2725, C0359 (Reprogram Transfer Case Control Module (TCCM)) - (Sep 14, 2005)
#05-06-04-055 Service Engine Soon (SES) Light On, Diagnostic Trouble Code(s) (DTC) P0442 Small Evaporative Emissions (EVAP) Leak and/or P0455 Large EVAP Leak (Reposition Fuel Filler Housing Seal) - (Sep 2, 2005)
#05-08-42-012 Trailer Park Lamps, Turn Signal, Stop Lamps or Trailer Brakes Inoperative (Tie Strap Trailer Wiring Harness to Trailer Hitch) - (Aug 31, 2005)
#05-06-04-053 Engine Rough Idle During Initial Warm-Up After Cold Start and Diagnostic Enhancements for DTC P0507 (Reprogram PCM) - (Aug 25, 2005)
#05-08-111-004A Window Outer Belt Strip Ends are Glossy (Wash Molding) - (Jun 16, 2005)
