Old 11-22-2005, 05:54 AM
brndray brndray is offline
brndray is off the scale
Today I did the driving light mod as and it works fine. However, I used a rocker switch with an led on it, but I can't seem to figure out how to get the led to work properly on it. It's a three pole switch so I used one for each relay and the other for a ground. When the headlights are on the led will not light up but when the headlights are off the led comes on. I moved the wires to different positions with the same results. I can only get the led to work when the headlights are off. I want the led to work only when the driving lights are on. Does anyone have any suggestions on how to do this?
