Old 09-07-2005, 12:30 AM
H3 Hummer's Avatar
H3 Hummer is off the scale
So if you are sitting in the passenger seat the air bag light is on if you are not in the seat the light is off. How does it know if you are sitting there or not?
H3 Hummer's Avatar
Old 09-07-2005, 12:36 AM
H3 Hummer's Avatar
Maybe I should re-phrase the question, what weight does the passenger air bag light come on automatically?
Old 09-07-2005, 12:55 AM
First Hummer is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by H3 Hummer:
Maybe I should re-phrase the question, what weight does the passenger air bag light come on automatically? </div></BLOCKQUOTE>
I think it works with the seatbelt warning.
Old 09-07-2005, 12:57 AM
H3 Hummer's Avatar
It know if you are sitting in the seat with the seat belt on or off?
Old 09-07-2005, 01:21 AM
Vincent Vincent is offline
Vincent is off the scale
Hmmm.....Not sure.
My dog is 75lbs and she is not heavy enough to turn on the air bag.
Old 09-07-2005, 07:18 PM
I believe it is 80 lbs. I think it mentions it in the manual.
Old 09-08-2005, 12:00 PM
Basically there is a "gel sensor" in the seat. As the gel is displaced at a specified weight, it actives a switch. Above a weight, the switch is closed and the air bag is activated via the SDM and will be deployed if required. Under a apecified weight, the switch is not closed, and the SDM will not deploy a bag.
