Old 04-18-2005, 11:52 AM
TouchdownTN TouchdownTN is offline
TouchdownTN is off the scale
I had a bad parking garage experience this weekend. The front luggage rack cleared fine, then I tore off the rear luggage rack and it took out both rear clearance lights. I was just wondering if anybody could point me in the best direction to order replacements. Also does anybody know how hard it is to put the luggage rack back on the truck. It appears to be OK. If anybody has the part #'s for the clearance light covers I'd appreciate it, I tried GM parts direct and couldn't find any listing for the H2's. Thanks in advance!
Old 04-18-2005, 12:09 PM
I believe Spike has the information you need.
Couldn't resist. I am sure someone will supply you with part numbers and options on the lights.
It sounds like your bar slid out the back of the rails, which is how you would have taken it off. There were some caps on the back ends of those rails but are probably missing now. The bar's sides just slide (from the back) back into the slides and you tighten them down.
Old 04-18-2005, 12:24 PM
partsguy partsguy is offline
I believe Spike has the information you need. <BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content"> </div></BLOCKQUOTE>LR outer 15060525
RR outer 15060526
Center (3) 15105495
Think I'm safe Spike Could be a frog set up!
It sounds like your bar slid out the back of the rails, which is how you would have taken it off. There were some caps on the back ends of those rails but are probably missing now. The bar's sides just slide (from the back) back into the slides and you tighten them down. </div></BLOCKQUOTE>
Old 04-18-2005, 12:36 PM
Klaus's Avatar
Klaus Klaus is offline
</div></BLOCKQUOTE>
Old 04-18-2005, 02:19 PM
Thanks for the info so far! I checked GM Parts Direct. They have 1 of the 2 lights for $40 each. I called my local dealer which is not very good and they do have the parts in stock but want over $60 each. Can someone point me in the right direction to find these lights? I have called a local salvage yard with no luck but I am going to call some others. Also does anyone have the part# for the caps that paragon mentioned. I didn't even know they were ever there! Thanks everyone!
Old 04-18-2005, 03:26 PM
LasVegas LasVegas is offline
LasVegas is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by TouchdownTN:
Thanks for the info so far! I checked GM Parts Direct. They have 1 of the 2 lights for $40 each. I called my local dealer which is not very good and they do have the parts in stock but want over $60 each. Can someone point me in the right direction to find these lights? I have called a local salvage yard with no luck but I am going to call some others. Also does anyone have the part# for the caps that paragon mentioned. I didn't even know they were ever there! Thanks everyone! </div></BLOCKQUOTE>Go here Hummer-Parts.com about $50 new
Jonahs
Old 04-18-2005, 03:33 PM
Sent ya a PM.
