Old 11-28-2005, 01:20 AM
Razor55 Razor55 is offline
Razor55 is off the scale
What's the trick to gaining access to the wiring for the tail lamps? There's go to be more than just the two screws and can see easily.
06 H3 Slate Blue
06 H3 Slate Blue
Old 11-28-2005, 01:25 AM
hummerdonthurtem hummerdonthurtem is offline
hummerdonthurtem is off the scale
Need to CAREFULLY pull the entire assembly after you remove the two screws. The assembly is also held in by two clips.
Black, Lux, Off-road Package, chrome brush, black step bar, mud flaps
Old 11-28-2005, 01:02 PM
hummerdonthurtem - In the past, I've been know to be a little too agressive removing things... I applied a little pressure trying to remove the whole assembly from the body of the vehicle and felt enough resistance to stop. Do I just gently keep pulling to overcome the friction from the clips?
06 H3 Slate Blue
Old 11-28-2005, 08:48 PM
hmrlvr's Avatar
hmrlvr hmrlvr is offline
Yes, just pull straight out, it will come.
WWW.BCBI.COM
Old 11-29-2005, 02:01 AM
you may need to wiggle it a little bit. just be careful since the assembly is one big plastic piece and the bulb wires are not that long. so as soon as the assembly pops out, be ready to stop pulling.
