Old 02-15-2006, 02:54 PM
V10MOJO2TOW V10MOJO2TOW is offline
V10MOJO2TOW is off the scale
i am replacing the stock tires on 2004 H2. i was told that master craft are identical to the BFGs currently on it. is this true? obviously same sizes
Old 02-19-2006, 01:06 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by MarineHawk:
V10, if you go offroad often, step up and get 37's. If not, get what you want because 2ply vs 3ply sidewalls won't really make much of a difference. </div></BLOCKQUOTE>
Will 37s rub at all, ever, on my stock H2? Or would I need to crank the torsion bars to keep that from happening?
I raised my torsion bars on my Sierra to put mere 33" tires on it. It was annoying and embarrasing when it still rubbed coming out of the parking garage and turning into an incline. I would love to have bigger tires, but no if they will rub. </div></BLOCKQUOTE>
a 37 X 12.50 tire on the stock rim may rub slightly on the frame or anti sway bar slightly, but only at full lock. Many of us run 37's ( I currently have 35's again) and have puched tthe rigs hard without much rubbing. Now, if you go to an aftermarket wheel and you get the wrong offset/ backspace, you'll get some rubbing for sure.
Old 02-19-2006, 12:10 AM
MarineHawk's Avatar
Old 02-18-2006, 03:22 AM
Old 02-15-2006, 05:01 PM
MarineHawk's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by V10MOJO2TOW:
i am replacing the stock tires on 2004 H2. i was told that master craft are identical to the BFGs currently on it. is this true? obviously same sizes </div></BLOCKQUOTE>
Depends in part on whether they have 3-ply sidewalls like the BFGs have.
Old 02-16-2006, 05:30 AM
Old 02-18-2006, 04:54 AM
no warranty no offroad just daily driving and suburban abuse and towing
Old 02-18-2006, 04:29 AM
Stay with 35's if you have an extended warranty or they'll try to deny your claims.
Or have 2 sets of wheels & tires.
Old 02-18-2006, 02:00 AM
these toyos stock size?
cost?
