Old 01-26-2006, 10:23 PM
Hart1 Hart1 is offline
Hart1 is off the scale
I can't believe the biased bull****.
Link
""The H2 is marketed as both a general purpose vehicle and as an off-road vehicle. However, H2 is not capable of geniune off-road travel due to its heavy weight, four wheel independent suspension, and a truck based body frame, although these provide very good riding quality. It is very common for H2 to snap a driving axle or get stuck on even some very low obstacles during off-road. Most likely, 95% of H2 buyers never really intended to go "off-road", and it is not recommended for them to do so.
A vivid example of the disadvantages of H2's independent suspension and heavy weight leading to a snapped front driving axle can be find here: http://video.google.com/videoplay?do...52499&q=hummer"""
As I understand it, there is a way to edit this information...Paragon, Help. If anybody can do it, it would be you.
Link
Old 01-26-2006, 10:35 PM
Bondage Bondage is offline
Bondage is off the scale
That's the beauty of Wikpedia...it can be edited and constantly evolved by the users. It don't say what it said no more.
Sean
Old 01-26-2006, 10:36 PM
frank6150's Avatar
Just click on edit this page, make your changes and you are done.
Old 01-26-2006, 10:37 PM
rodster rodster is offline
rodster is off the scale
Odd, but the link target page does not contain the text in your post.
\'05 SUT
Old 01-26-2006, 10:38 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Bondage:
Sean </div></BLOCKQUOTE>
Nice.
\'05 SUT
Old 01-26-2006, 10:40 PM
Good Job!!
I can now watch the State of the Union address in total bliss...
Old 01-26-2006, 10:42 PM
""Jealous old-timers in Jeeps often try to degrade the Hummer, but a loyal following haven proven its worth and struck back in the 4x4 ...""
Sweet! That's more like it. lol
frank6150's Avatar
Doh, I just deleted a bunch of it.
Old 01-27-2006, 01:46 AM
It's still there. C'mon you tech guys - add more and make it more factually impressive!
Sean
Old 01-27-2006, 02:17 AM
Somebody has been busy. Check out the new video link.
\'05 SUT
Old 01-27-2006, 02:32 AM
Old 01-27-2006, 03:05 AM
Efrain's Avatar
Efrain Efrain is offline
Efrain is off the scale
Somebody has been busy. Check out the new video link. </div></BLOCKQUOTE>
A pat on the back to whoever edited it!
Old 01-27-2006, 03:14 AM
Beastmaster's Avatar
Beastmaster is off the scale
Guys - getting into an edit war will only make it worse. This entry gets monitored enough as it is. Don't add to the fire.
M101A2 Trailer
Old 01-27-2006, 04:02 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Beastmaster:
Guys - getting into an edit war will only make it worse. This entry gets monitored enough as it is. Don't add to the fire. </div></BLOCKQUOTE>
Monitored by whom??? And why not edit it to make it TRUE rather than biased nonsense?? If the fire's burning anyway, let's keep it going in the right direction!
Sean
Old 01-27-2006, 01:57 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Guys - getting into an edit war will only make it worse. This entry gets monitored enough as it is. Don't add to the fire. </div></BLOCKQUOTE>
They started it with a very non-objective viewpoint (in other words, they lied their ass off).
What are we to do, Lay down and die?
Old 01-27-2006, 02:30 PM
Arizona Hummerboy's Avatar
I sure would like to see a Chevrolet Tahoe or GMC Yukon follow the Hummer H2 on some hard core trails for a day.
Old 01-27-2006, 02:43 PM
I just added this:
Debunking the Tahoe Frame Myth:
The final frame assembly is made up of 3 sections. The front uses a modified GM 2500-Series utility frame. The mid-section is all new and is completely boxed. The rear section uses a modifed GM 1500-Series frame which is upgraded for 8000 pound gross vehicle weight.
Old 01-27-2006, 03:02 PM
ShaggyX ShaggyX is offline
You guys crack me up.
Old 01-27-2006, 04:23 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Hart1:
I just added this:
The final frame assembly is made up of 3 sections. The front uses a modified GM 2500-Series utility frame. The mid-section is all new and is completely boxed. The rear section uses a modifed GM 1500-Series frame which is upgraded for 8000 pound gross vehicle weight. </div></BLOCKQUOTE>
Excellent! As the great Ronaldus Maximus was fond of saying, FACTS are stubborn things....
Sean
