Old 04-26-2006, 01:41 AM
AUHUMMER's Avatar
AUHUMMER AUHUMMER is offline
AUHUMMER is off the scale
OK...I've searched the site and haven't found another DA who has, or will admit to, cracking the gauge cluster lens. Actually, I have 9 and 7 year-old boys with what appear to be ironclad alibis but their records are working against them. Anyway... I need a part # or info on a replacement gauge lens---if it even is a separate part. By the way, new to the site and the H2---both are a blast.
Old 04-26-2006, 11:44 AM
kodiakz kodiakz is offline
kodiakz is off the scale
I think those boys are going to be pulling a lot of weeds this summer as that cluster is all one piece--the front lens does not come off (at least not normally). New clusters only cost about $250 and you can get custom ones if you like as well.
Old 04-27-2006, 01:36 AM
AUHUMMER's Avatar
Thanks for the response---that's what I suspected would be the case. But, I can say that at $250+/- my tolerance level has gone way up. Besides, the cracks (2) are at the lower left in front of the coolant temp. You wait, when the sweat starts flowing, one of them will ge ratted out. That sibling loyalty only goes so deep at their age. Thanks again
Old 04-06-2007, 06:01 PM
AUHUMMER's Avatar
Default Re: Gauge cluster lens part#?
Just an update in case any of you have the same problem. I found the lens at alldiscountparts.com for $66 plus shipping. Actually, it is the lens attached to the black bezel that surrounds the gauge faces. Easy, but tedious, install. Be careful---lots of plastic and small clips. Took about 2 hours first time---could probably do it again in 30-45 minutes.
Old 10-28-2008, 09:04 PM
Cazador Cazador is offline
Cazador is on a distinguished road
Do you have a part number for this? I have a small crack on the lower right side. Doesn't really bother me, but I'd like to replace it.
Old 10-29-2008, 01:51 AM
AUHUMMER's Avatar
Don't have a part #, but if you go to alldiscountparts.com and enter your vehicle year, make, and model--then pick "Instrument Panel" then "Cluster and Switches", then "Lens" you can see illustration and price. Sorry but I long ago threw away the old info and packaging.
Old 10-29-2008, 03:06 PM
Sounds good.
Thank you!
