Old 01-15-2006, 04:03 AM
W1N's Avatar
W1N W1N is offline
W1N is off the scale
I ordered blacked out door handles for my becoming H2 (arriving in only weeks or so) and I'd like to hear from somebody with experience that what risks there are related in the process of changing the door handles. I'll have the GM mechanic to do the job, but I saw the post (actually using the find function) related to this issue and more less it seemed that changing the door handles is not a trivial job. Just like to know what to expect before I go on and have it done...
Thanks!
W1N's Avatar
W1N W1N is offline
Thanks!
Old 01-15-2006, 04:48 AM
Expect it to take longer than they tell you.
Congrats on the FIND button!
Old 01-15-2006, 04:53 AM
Then again:
http://elcova.com/groupee/forums/a/tpc/f/6706011751/m/8...141093531#8141093531
Good stuff:
http://elcova.com/groupee/forums/a/tpc/f/6706011751/m/6...106047891#2106047891
Better stuff with pics:
http://elcova.com/groupee/forums/a/tpc/f/6706011751/m/8...906077715#8906077715
You suck at using the FIND button.
Old 01-15-2006, 05:01 AM
rodster rodster is offline
rodster is off the scale
It's not a technical job that requires great skill but it is tedious. Anybody with the right tools and lots of patience can do it.
As for risks, if the mechanic doesn't remove the windows (it's not necessary), the only real risk is breaking the plastic fasteners that hold the door panel on. Another possible but not likely problem is, under the door panel there is a plastic/foam membrane that provides, I assume, some kind of climate and sound insulation. If that gets mangled I guess it's not good. The last link Ken posted shows the plastic/foam.
\'05 SUT
Old 01-15-2006, 05:34 AM
W1N's Avatar
W1N W1N is offline
You suck at using the FIND button. </div></BLOCKQUOTE>
Damn, you must be right! I didn't get any of that stuff out of there...
Well thanks anyway!
