Old 09-16-2005, 09:09 PM
Game Over Game Over is offline
Game Over is off the scale
What exactly is Retained Accesory Power ?
Old 09-16-2005, 09:13 PM
Hummer Guy's Avatar
Hummer Guy is off the scale
Basically it allows you to operate the accessory power ports after the engine is off. Some have auto shut-offs if the battery starts to die. I'm sure some on here can offer a more technical answer if you like.
-Brian
http://www.hummerguy.net
Old 09-16-2005, 09:25 PM
DWPC DWPC is offline
DWPC is an unknown quantity at this point
It also lets you close the windows/sunroof after you've shut off the engine but before you remove the key (I think).
'06 H3 Adventure (9/2005-1/2013)
Old 09-16-2005, 09:32 PM
H3OH H3OH is offline
H3OH is off the scale
And you can continue to listen to the radio and will stay on until you open the door.
\"In the poker game of life, women are the rake man. They are the f$#@%n\' rake.\"
__________________________________________________ _____________________
\'06 H3 - Birch White, Auto, Lux Pack (with Homelink), Chrome Pack (with Crossbows), Chrom
Old 09-16-2005, 09:35 PM
Webb70 Webb70 is offline
Webb70 is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by DWPC:
It also lets you close the windows/sunroof after you've shut off the engine but before you remove the key (I think). </div></BLOCKQUOTE>
No you can remove the key. Everything (accessories)stays on till you open the door.
Old 09-17-2005, 04:24 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Hummer Guy:
Basically it allows you to operate the accessory power ports after the engine is off. Some have auto shut-offs if the battery starts to die. I'm sure some on here can offer a more technical answer if you like. </div></BLOCKQUOTE>
Any answer is good and technical to a newbie like me So basically it's serves as a convenience to do things when engine is off but not necessary ? Reason I am askin is I'm trying to get a wire harness for an aftermarket stereo without having to get the PAC-OS2 module.
Thanks for all your replies
Old 09-17-2005, 09:44 AM
As others have stated, RAP allows you to turn off the vehicle and the power to certain accessories stay hot until a door is opened. The RAP relay will power the radio, wipers, sunroof, power windows, and my radar detector. If the BCM sees a door switch input, the RAP relay is turned off. It will also turn off the relay afte approx. 10 minutes, or if the battery goes below a set amount of reserve power.
There is also another feature called Battery Rundown Protection and Inadvertent Power, where the BCM monitors the courtesy lamps with the ignition turned Off. So, if you leave your courtesy lamps on, and the BCM senses no movement of any of the door switches (open/closing of doors) in a twenty minute period, it will turn off all the courtesy lamps until ignition switch is turned on (or in some vehicles, if a door switch input is received...not sure about the H3 on the door switch input).
