Old 06-28-2005, 01:09 PM
wannabeH3's Avatar
regarding getting them under water.... they are vented right?
(with insurance)
wannabeH3's Avatar
(with insurance)
Old 06-28-2005, 04:42 PM
wannabeH3's Avatar
anyone?
(with insurance)
Old 06-28-2005, 04:49 PM
Hummer Guy's Avatar
Hummer Guy is off the scale
The axle and tranny are vented, but they're raised.(somewhere above or around the 24 inches max water fording)...
-Brian
http://www.hummerguy.net
Old 06-28-2005, 04:51 PM
Not that I plan on it but if I understand correctly, if I end up going deeper than 24" there could be tranny problems in my future?
Old 06-28-2005, 05:24 PM
Desert Dan's Avatar
You may be able to extend the axle vent lines and the vent from the trans.
Sometimes the trans is vented on the top and a fitting and longer tubing could be added to that.
On my Jeep, the front axle vent is about as high as the top of the radiator and the rear axle vent goes up inside the rear inner fender well or frame.
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 06-29-2005, 07:40 PM
Hummer Guy's Avatar
Not that I plan on it but if I understand correctly, if I end up going deeper than 24" there could be tranny problems in my future? </div></BLOCKQUOTE>
I don't know that they are right at 24 inches, but I wouldn't push that limit if I could help it...You'll probably end up with more than just tranny problems. When I used to off-road, the first thing I saw in H1s go was the electronics...trannys went bad from non-water off-road abuse..in H2s the water fording was very close, and the check engine light would come on sometimes, but it would typically dry out overnight..
-Brian
