Old 04-20-2005, 07:27 PM
intimidator intimidator is offline
intimidator is off the scale
i'm looking to replace my stock chrome wheels with kaotic nt1 17"x 10" wheels.and use the stock tires. i know the backspacing is 4.5" on the kaotics but i don't want them to stick out of the wheel well too far. so if someone might have a picture from the front of their rig so i can see what it will look like i would greatly appreciate it. also any h2 with 17'x 10" wheels with a 4.5' backspacing would work. thank you. and yes i did a search but all of the pictures are from the side.
Old 04-20-2005, 08:41 PM
thank's phil.3"to4" is a little too much.
Old 04-21-2005, 01:23 AM
HGW HGW is offline
HGW is off the scale
This is my H2 with 18 X 10 wheels, 4.5 backspacing and 38 X 15.5 tires.
If you get a 17 x 10, the tires will stick out slightly but not as much as you see here---tire is 15.5 wide--I forget the width of a stock tire.
Old 04-21-2005, 08:21 AM
that looks great. now i think i'm going to go with 17'x 10" with 37' tires. thanks alot for the help .
Old 04-22-2005, 01:24 AM
HGW HGW is offline
Intim:
Here is a pic of my H2 with 37" tires, 17 X 10 rims, way before I started customizing.
These are ProComps 37 x 13.5 x 17. I have them here with less than 200 miles on them. They were too small for my lift size so I took them off right away.
PM me if you are interested in them--I am right up the street from you. I am in no rush to get rid of them. Someday someone will see them in my shop and snatch them up.
Old 04-22-2005, 08:24 AM
they look like american racing wheels? if the price is right i might snatch them off you.
Old 04-22-2005, 09:51 AM
HGW HGW is offline
They are AR wheels and you can have the wheels for a song. AR wheels are cast aluminum and are not worth the price (300 each new) new so they will go cheap used.
I use WELD Evos now on all my H2's. I can get you a set to match those tires and your H2 will look fantastic. If you want to run the AR's for a while, I can let those go with or without the tires.
PM me when you can and I will give you a call.
