Old 02-21-2006, 05:12 PM
peter umino peter umino is offline
peter umino is off the scale
I'm trying to figure out if the H2 alarm will arm itself when the doors are locked with the key, but not with the fob...the hummer only came with the keys, but no fob (portion that has the alarm button)
thanks!!
thanks!!
Old 02-21-2006, 05:16 PM
Try using the find feature, I think this was talked about before. I believe ya have to lock it with the remote to arm it....Also check th owners manual.
Old 02-21-2006, 05:26 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by DDWH:
Try using the find feature, I think this was talked about before. I believe ya have to lock it with the remote to arm it....Also check th owners manual. </div></BLOCKQUOTE>
I did try searching, but didn't find anything...I don't have the owners manual - and I haven't even gotten the car yet; otherwise I would have tried locking it and seeing if the alarm came on.
thanks
Old 02-21-2006, 05:34 PM
You can D/L the manual in PDF form from here for 03, 04, 05
http://www.elcova.com/h2/details.html
Old 02-21-2006, 05:55 PM
http://www.elcova.com/h2/details.html </div></BLOCKQUOTE>
perfect!!! thanks so much! (FYI: the only way to arm the alarm w/out the fob is to use the power lock button on the inteiror of the door while the door is open and then to close it...otherwsie you need the fob to activate the alarm)
thanks again!
