Old 03-16-2005, 03:35 AM
HummDinger HummDinger is offline
HummDinger is off the scale
Here is my solution for mounting a Hi-Lift Jack. There seems to be no good solutions to mount these unless you have a roof rack. I designed some simple plates, then used part of the mounting hardware from Hi-Jack's 4xRAC kit. This requires absolutely no drilling required and is rock solid.
Old 03-16-2005, 03:38 AM
Here's a closeup shot.
Old 03-16-2005, 03:44 AM
H2Finally's Avatar
Great job! Now if only you can resize the pics a teeny bit smaller, and MOVE IT TO THE H2 SECTION, it would be perfect!
Can BLING Get You Home?
Old 03-16-2005, 04:16 AM
Done. Thanks for your comments and advice.
