06-19-2004, 04:23 PM
Is anyone running 17x10 inch rims with no lift? If so do you have issues with rubbing? I am considering 10 inch wide rims with 37x12.5 BFG's
06-20-2004, 09:26 AM
My stock rims and tires rub on the sway bar at full lock on both sides.
Yellow 03 Adventure w/black Grill, UM8 Touch Screen Navigation Radio, U2K XM Digital Radio, Remote 6-CD Changer, JBA Titanium Headers, Corsa Off-Road Sport, Airaid Filter & MIT, Nology Wires & Plugs, S&P Pro-Flash, Warn 9.5ti w/X-Line, Toyo Open Country M/T 37x13.5.
06-20-2004, 04:45 PM
I have run 17x10 rims and 37x12.50x17 Goodyear MTR for 27,000 miles with no rubbing. Even offroading they do not hit. I adjusted the torsion bars to raise the front end, but my H2 sat very nose low when I bought it. The rims have a 4.5 inch backset.
06-20-2004, 07:28 PM
Hey Bevo,
If your "stock" setup rubs on the sway bars I'd get it checked out before the warranty expires.
2003 Yellow H2 LUX (Sold)
06-21-2004, 12:37 AM
kdio, that is the set up I was thinking about, but then I found a set of 17x8 with funtioning bead locks and I am wondering if that might be a better way to go. Im thinking the sidewall movement might be helped with the 8" rims. Too many decisions!
I know, I know, bead locks are not D.O.T. approved but with all the fake ones these days im sure no one will even notice  .
Thanks for the info and your expierence should I go with the 10's
