Old 11-01-2005, 09:01 PM
mannytranny mannytranny is offline
mannytranny is off the scale
that have a NAv sytem are NOT being built? My dealer said that he isn't sure but there is a problem.I ordered mine Sept. 28 and still no build date because of a NAV problem. Anyone know when it will be solved?????
Old 11-01-2005, 09:10 PM
... and you won't see it until the 2007's are released at this rate.
Between what my dealer has told me and some others from the board, the NAV's are on constraint due to a 20% failure rate at the factory: they are burning up. I had the dealer take the NAV option off of mine and I will go aftermarket or put the H2 NAV in if it is possible.
Old 11-01-2005, 09:11 PM
HoKC's Avatar
HoKC HoKC is offline
HoKC is off the scale
Do not know when it will be solved but i have heard it was a supplier quality problem with the fit and finish.
Old 11-01-2005, 10:50 PM
Guess I should do some calling around tomorrow to find out the real reason. From what I have seen with release of these items, it is primarily fit/finish, or the supplier just cannot deliver the quantity of units everyone wants.
Old 11-01-2005, 11:13 PM
Old 11-02-2005, 12:09 PM
I had planned on getting the NAV but even if they were shipping now, I think I will got with Blown Z06's carputer instead. You get the NAV and everything else along with a full blown PC for the same or less money.
Old 11-05-2005, 01:03 PM
Just heard from Hummer customer service. The NAV is on constaint due to supplier problem. It will be 4-6 weeks before a NAV equipped H3 can be ordered. I'm getting worried because my GMID certificate might expire before I can get an order in. My dealer said that if it is ordered before January then my GMID certicate will still be good. What happens if the certificate expires? Can I get a replacement?
Old 11-05-2005, 08:22 PM
J from the D J from the D is offline
J from the D is off the scale
You can get a new one from the person who gave you the original one... if they have not given them to someone else by then.
Second only to roof marker lamps, NAV systems are a real thorn in my side.
All I can say is that 'supply and demand' are NOT the only reason that there aren't many available.
