Old 11-06-2005, 11:57 PM
VTSTOMPER is off the scale
Where did most of you find you needed to trim when you added 37" tires. *no life* duh
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 11-07-2005, 01:41 PM
TXSUT's Avatar
TXSUT TXSUT is offline
My tires did the trimming for me. LOL
I'll try to take some pics of the holes for you.
Old 11-07-2005, 02:35 PM
Thanks bud!
Old 11-07-2005, 02:51 PM
rodster rodster is offline
rodster is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by TXSUT:
</div></BLOCKQUOTE>
Ditto. But then the hole edges started to curl toward the tire, which had the same effect as a playing card clothespinned to kid's bike. So I cut the hole bigger with my pocket knife.
Rubbing for me is only on the right side wheel housing. If I had to do it all over again, I'd install the tires, drive a few miles, look for rub spots then remove the tire and attempt to remount or otherwise adjust the housing. The rubbing I had was so minor that might have solved it.
\'05 SUT
