Old 07-01-2005, 01:52 PM
Arizona Hummerboy's Avatar
I had to replace the Water Pump this week on the H2, it was starting to leak. I only have around 43,000 Miles on it.
Has anyone out there, had to change out there Water Pump yet?
Old 07-01-2005, 03:42 PM
LasVegas LasVegas is offline
LasVegas is off the scale
Nope. Unusual but our desert heat does take a toll on vehicles.
Jonahs
Old 07-01-2005, 07:31 PM
Hummertech is off the scale
OH YEAH. I've changed dozens of them. Many of them start leaking at 30-40 thousand. It's a good idea before you go out of warranty to crawl under yours and inspect it for any small
coolant leaks, you'll often see a drop or two of coolant from the front oil pan bolts
Old 07-06-2005, 04:42 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
never replaced a pump yet but gaskets are terrible, seems they perfected the pump and used ****ty gaskets. make sure its not just coming from the gaskets before you replace your pump.
1998 Chev Z71
2007 Chev Trailblazer SS
Old 10-28-2005, 05:42 PM
10 MPG 10 MPG is offline
10 MPG is off the scale
The dealer quoted $600+ to replace my leaking water pump. I have around 47,000 miles so I guess it's within the ballbark. Sucks though.
Old 10-28-2005, 06:40 PM
Klaus's Avatar
Klaus Klaus is offline
You should have bought an extended warranty!
