Old 05-10-2005, 11:16 PM
96 hummer 96 hummer is offline
96 hummer is off the scale
I just bought a 96 turbo but went to change the oil and it took 4 quarts and says its full. the manual says the case takes 7 with out the filter change? The orig orner did say the dealer changed the engine out in 1998. Does the 98 take less oil or could it have the wrong dip stick. I took 7 quarts out.
Old 05-11-2005, 02:31 AM
Beastmaster's Avatar
Beastmaster is off the scale
7 Quarts is the actual use if you don't change the filter. 8 quarts if you do.
This is per the 1997 and 1998 Service Manual.
Hope this helps!
Steve
M101A2 Trailer
