Old 02-18-2006, 09:05 AM
primal-hunter primal-hunter is offline
primal-hunter is off the scale
Has anyone had this problem and if they have found a solution - would they mind sharing it with the rest of us?
The problem is that when you are driving down the highway and there is a strong cross wind coming from the passenger side, there is a strong hum coming from the hood area. When you change directions it goes away.
Please advise.
Please advise.
Old 02-18-2006, 06:31 PM
My Wife\'s Hummer My Wife\'s Hummer is offline
My Wife\'s Hummer is off the scale
i drove in some strong winds today, and in some test drives in the last month. i did not notice this, but might not have been in the same angle as yours. this might just be something that you have to live with.
have you checked to make sure your hood is aligned right? if it is sitting up to high, there is an adjustable stopper in the front corners where the hood comes down. you might be able to tweak that a little.
It is actually my hummer for now!
06' H3 Boulder Grey, Lux, Off-Road, AirRaid CAI, TB Spacer, AVIC-D2
Old 02-21-2006, 04:24 AM
bmoser1 bmoser1 is offline
bmoser1 is off the scale
I have noticed this as well. I thought that the humming sound was coming from the side mirror as it was vibrating during the hum. Just my observation.
Black H3, Adventure Package, Rocker Panel Protectors, Undercarriage Protection
Old 02-21-2006, 01:54 PM
CampMaster CampMaster is offline
CampMaster is off the scale
Chevy Avalanche owners experienced something similar... with the bug deflector installed, it changed the air flow enough to cause the windshield side moldings to vibrate/flap in the wind. The fix was to install the double sided tape under the windshield side moldings.
Might be worth checking out, even though a bug deflector is not necessarily involved; it does sound like the change in wind direction does create the noise/vibration.
Old 02-21-2006, 01:59 PM
Kiraco's Avatar
Kiraco Kiraco is offline
Kiraco is an unknown quantity at this point
I have noticed the sounds but it is coming from the A pillar..
Old 02-21-2006, 11:48 PM
Mike E's Avatar
Mike E Mike E is offline
Mike E is off the scale
I know exactly what your talking about. Mine does the same thing. I would be willing to bet that it's air going through that hood vent on the drivers side. I've checked all the plastic trim around the windshield and everything is very secure.
____________________________
Old 02-22-2006, 12:02 AM
Demo's Avatar
Demo Demo is offline
me 2, i hate noise
Old 02-24-2006, 02:41 PM
Put masking tape over your vertical side moldings at the windshield and see how it sounds. Use painter's tape if you've got it--no residue. If so, take it to the dealer and let them take it from there.
Old 02-24-2006, 08:03 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Planohummer:
Put masking tape over your vertical side moldings at the windshield and see how it sounds. Use painter's tape if you've got it--no residue. If so, take it to the dealer and let them take it from there. </div></BLOCKQUOTE>
A good very good idea. Another idea if the tape does not solve the problem is to remove the radio antenna, and see if the humming noise goes away.
The H3 does come with the wire wound antenna (wire wound on the outer part), and that stops a lot of vibration from the antenna which causes a resonance that sounds like a hum.
However, under certain conditions, nothing you can do to an antenna will stop a possible humming noise.
Old 02-24-2006, 08:07 PM
HumbleAg HumbleAg is offline
HumbleAg is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Kiraco:
I have noticed the sounds but it is coming from the A pillar.. </div></BLOCKQUOTE>
ditto. A-pillar molding on mine is loose and doesn't cover roof rack molding, going to let the dealer fix it next visit.
Old 02-26-2006, 05:08 AM
MotorsportsAuthority aka Dragon's Avatar
MotorsportsAuthority aka Dragon MotorsportsAuthority aka Dragon is offline
MotorsportsAuthority aka Dragon is an unknown quantity at this point
chevy owners experience this with their bug deflectors because it caused a rubber flap that's on both sides of the vehicle (who's function is who knows what) to actually flap rapidly. it sounded like it was coming from the a-pillars. more of a crackling sound like the windshield was about to shatter. anyway, i took my shield off and it disappeared. from some quick looks at some pictures, i don't see these flaps anywhere on the h3's.
01 Toyota Celica GT-T .:|:. 04 Chevrolet 2500HD Duramax .:|:. 01 Lexus RX300 .:|:. Under Construction
Owner: Motorsports Authority, Inc.
MYSPACE
Old 02-26-2006, 11:32 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by HumbleAg:
ditto. A-pillar molding on mine is loose and doesn't cover roof rack molding, going to let the dealer fix it next visit. </div></BLOCKQUOTE>
Just a suggestion, hold off on having the dealer replace the A-pillar moldings until the new ones are available in May; along with the new roof rail moldings that won't crack.
The new A-pillar molding will fit better and overlap the roof rail molding better than the existing ones.
Old 05-24-2006, 06:54 PM
Black_H3 Black_H3 is offline
Black_H3 is off the scale
Default Re: Noise coming from the hood area with strong wind
Good.. I thought I was the only one Mine starts the damn hissing sound at about 95 mph on the freeway. Took it in and they looked at the drivers side intake and they said nothing is wrong with it. I might try the tape thing over the screen and see if that helps.
Is the A-piller really used as an intake like on a H1?
Black, LUX, Ebony/Morocco Leather, brushguard, crossbows, 2 A-1000 Vizualogic tv/dvd, game connections, 35% tint
Old 05-25-2006, 07:43 AM
blindzebra's Avatar
not to be southern, but "ya'll" got to be kiidden me! You didn't turn on the monsoon!!!!!
