01-13-2006, 12:30 AM
I know there has been several posts on this topic and some confusion. I upgraded to the 6 disc stereo to replace may base radio. Installation took about five minutes. My dealer reprogramed the radio and it works fine, no problem with sound levels being cut in half.They charged me 19 dollars to do it. Lynch Hummer, Chesterfield, Mo.
Black H3 Adventure
Black H3 Adventure
01-13-2006, 12:55 AM
Good Deal. I did the same thing last week and my dealer charged me $50.
____________________________
01-13-2006, 12:58 AM
I will do it as well. Earlier posts indicated that the volume level would be cut in half. I have the moonsoon system, I'm not sure if there is a 6 disc without moonsoon
01-13-2006, 01:11 AM
from the two threads i think low volume was 6 disc no amp if you have monsoon you already have the amp  so you will be thumpinnnn !!!!
01-13-2006, 01:32 AM
I meant I bought the 6 disc stereo that was part of the moonsoon system via Ebay. In my H3 I have the base stereo. Anyway I will just try it.
Thanks,
Eric
01-13-2006, 03:21 AM
if volume is issue after install just get an affordable amp
01-13-2006, 12:44 PM
H3Eric, you should be fine. I added the 6 disc premium radio from the standard radio and the volume is fine.
01-13-2006, 04:39 PM
H3Eric, I was concerned too, but my H3 just had the base radio without the monsoon speakers, and the 6 disc works great, no volume loss, I think it is even louder with cd's over the am/fm.
Black H3 Adventure
01-13-2006, 08:45 PM
Thanks, I will change it next week.
01-19-2006, 03:15 AM
I finally installed my 6 disc radio instead of the stock radio. It sounds great and it does not lock, so I don't have to go to the dealer.
This is very strange as all other posts here about the change talked about the unlocking of the radio by using a tech-2 at the dealership.
01-19-2006, 04:57 AM
I did the same thing have monsoon with single cd, bought 6 disc radio on e-bay.My first question how did you remove the cover plate so you could remove the radio,any special tools required?
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by H3Eric:
This is very strange as all other posts here about the change talked about the unlocking of the radio by using a tech-2 at the dealership. </div></BLOCKQUOTE>
01-19-2006, 12:03 PM
Stick your fingers in the two accessory ports at the bottom lower right and pull up and out. The panel will pop off.
01-19-2006, 04:57 PM
disconnect the battery first before you do anything.
01-19-2006, 05:13 PM
Na, just cram your fingers in the sockets. It'll be fine.
--yes, disconnect the battery.
01-19-2006, 05:16 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Mike E:
--yes, disconnect the battery.  </div></BLOCKQUOTE>
And move the shifter into 1st/2nd before you disconnect the battery. It will make things a lot easier.
01-19-2006, 06:14 PM
Hi Trail humper...........I don't have a reply to your post I just wanted to say Hi.
01-20-2006, 01:09 AM
the same here, maybe will catch you in the chat room soon.<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by MrsRobinsn2000:
Hi Trail humper...........I don't have a reply to your post I just wanted to say Hi.  </div></BLOCKQUOTE>
Black H3 Adventure
01-20-2006, 05:34 PM
If there is a set day and time that you know you will be in the chatroom just let me know. You can either post it here or email me. Talk to you soon.
01-23-2006, 05:04 AM
Can anyone tell me if the 6-disc changer can play MP3 CD's also?
