Old 11-14-2005, 10:00 AM
Cranky Steve's Avatar
Cranky Steve Cranky Steve is offline
Cranky Steve is an unknown quantity at this point
Yep, $49.95!! And it's a killer set up! But you have to have an extra set of rims and some skills with power tools.
Check it out at Inchworm Gear http://www.inchwormgear.com/store/index.php?cPath=34
Full details on how it works here:
http://www.pirate4x4.com/forum/showthread.php?t=340906
This setup has been fully tested for 2 years on all types of terrain from snow to rocks.
I picked up a set of Spun aluminum rims cheep to use with Inchworm's Beadlock Screws
The crew at Inchworm helped me mount up my tires, but before we did that, I did some mods to the rims:
1) Tapped the original Valve Stem hole with a ¼” NPT tap, and plugged it.
2) Drilled and tapped 2 new holes close the center to relocate the valve stem and add a thumb screw drain cock.
3) Used Dow Polyurethane Windshield adhesive on the bead seat area in prep for the beadlock screws
Total cost so far:
4 Rims - $100
2 tubes Dow Polyurethane Windshield adhesive - $15
4 Husky Compressor drain cocks (Home Depot) - $13
1 Set Inchworm Beadlock screws - $49
$177 so far.
Pics:
The jig for installing the screws:
Backside:
Frontside:
BS Member since '04
F.B.B.F.U.M
Official Hummer Forums "Rice Grinder"
http://www.rocknroll4x4.com
http://rubicontrailpatrol.org/index.php
http://www.friendsoftherubicon.com/
http://www.Pirate4x4.com Tool and Shop Talk, Vendor, & Toyota Truck and 4Runner Talk Forum Moderator
Total cost so far:
4 Rims - $100
$177 so far.
Pics:
Backside:
Frontside:
BS Member since '04
F.B.B.F.U.M
