Old 07-21-2005, 07:34 PM
H2_SUT_SC H2_SUT_SC is offline
H2_SUT_SC is off the scale
Ok, I've searched the forums through and through and I've seen a lot of guys running 37x13.50's whether it's on 18's, 20's, 22's or even 24's. I also noticed that there's a slight bit of rubbing in some of those applications.
My question is can I fit that tire on a 22x11" wide rim. Ok...I now the tire will "fit" I mean will the rim/tire combo fit on the H2 w/o a lift. If I crank up the torsion bars just a tad will that help clear it? Will that give it an akward look?
I know the 325/60R20's fit on an 11" wide rim fine. But like I said in another post they are 35.2" tall whereas the 37's are 37.1" tall, plus an inch wider.
I spoke with my dealer and he's seen a few sets of 22's and one set of 24's put on with the 37's. He said in one instance they had to shave the frame on the rear where the inner part of the tire was rubbing. No biggie there. Secondly he said the other place he saw rubbing was when you turned the steering wheel to lock the front inward tire would rub on the control arm. I would think a different offset might fix that.
Last question is if turning up the torsion bars a tad and throwing on 37's do your guys' trucks still fit in a standard garage? I noticed it's close now - only had mine for 2 days now.
