Old 03-25-2006, 05:28 PM
87Warrior 87Warrior is offline
87Warrior is off the scale
Howdy folks, its been awhile since I have stopped by, as the tank has been trouble free!
Just took the tank out for a Ski trip. While sitting at idle I noticed the air pump kept comming on and turning off. My first thought.... the luggage in the back.
Once we returned and unpacked, I took another gander at the rig. The driverside rear end is sitting about 2 inches lower than the passangerside. Besides the top obviously sitting lopsided, eyeing the bumper to the axle give the same result.
When ever the height control button is pressed, the passangerside begins to lift quicker than the driverside. However, within a few seconds the driverside shoots up and inflates at the same rate as the passangerside.
What gives? Is there a pressure sensor in the air bag that is going bad? or is it a leaky air bag? I am at a loss here.
___________
03 H2
03 Rubi
Old 03-25-2006, 05:34 PM
Check the link arm directly inboard of the tire-it's probably broken. You can superglue/plastic weld it together until you get a new one.
Old 03-25-2006, 11:39 PM
MovinH2's Avatar
MovinH2 MovinH2 is offline
MovinH2 is off the scale
Yup.
Old 03-27-2006, 01:01 AM
I believe I located the arm. Is it about 4inches long, plastic, with some ribbing? If so, it is not broken. After a quick look over, everything else under the machine seems to be fine.
___________
03 H2
03 Rubi
Old 03-27-2006, 05:17 AM
Check the otherside. AlecW had his system go haywire in Moab when one broke. BTW, A ziptie works great for that repair.
