Old 09-26-2005, 11:10 PM
shipbldr shipbldr is offline
shipbldr is off the scale
The "Inner Tim Allen" in me has surfaced again. This time during an air horn installation.
The roots of this one lay in the end-of-trail event all H2 owners know: The 20-40 minute tire refill.
After blowing about 45 minutes airing up... I began the search for a better way. I found that most 12vDC air pumps only put out around 10L max.
Knowing there had to be a better way, I tapped into my friends in south china an found it. I found a shop in south china that makes a 150L per minute air pump. It runs on 12vDC and draws about 60 amps.
So of course... I ordered one.
Then I thought about it and decided that it would go even faster if I have an air tank.
Having just installed the Gobi rack... I had lots of space up top.
Knowing I was thinking of installing an air horn, I called and asked what size air tank was suggested. The horn vendor sugegsted a .5 gallon tank.
So I bought a 5 gallon tank. I figured a 900% reserve couldn't be a bad thing.
I also bought a Viair 145 psi pressure switch.
And a set of horns....
I spent the better part of tonight fabricating a mount to put the horns in a semi-protected place on the Gobi rack.
The black spray paint is drying on the new mounts right now.
I'm going to run 3/8 hose from the tank to the horn. I hope it can breath through that...
Report on the expected carnage tomorrow after parts are dry and installed....
