Old 12-15-2005, 08:36 AM
gcraybas gcraybas is offline
gcraybas is off the scale
If you notice your keys banging into dash while accelerating or braking, I found an easy fix. Purchase a sticky pad by Handstands @ brookstone. Cut pad into small square an place on dash @ impact area. This material is spongy with a tacky non-adhesive backing. Check out http://www.handstands.com for pads or gadget grips(pre-cut squares).
Old 12-15-2005, 12:00 PM
ree's Avatar
ree ree is offline
There is an even easier one, just have your key on the very small keyring that comes with the remote and don't use the larger key ring. Problem solved. </div></BLOCKQUOTE>
That only works if you carry the H2 key separate from any other keys you have. While I'm not a key hound (I only have a few other keys on the ring), I like to keep all my keys together...if nothing more than to occasionally give me a sharp jab to the g'nads when I sit down, not
'03 pewter base H2
Old 12-15-2005, 01:14 PM
is the problem the noise or possible scratches to the dash? scratches add character, and the volume buttons on the steering wheel or stereo eliminate the noise. i recommend Motorhead to completely eliminate all squeaks and rattles.
Old 12-15-2005, 02:24 PM
ree's Avatar
ree ree is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by shorterbus:
is the problem the noise or possible scratches to the dash? scratches add character, and the volume buttons on the steering wheel or stereo eliminate the noise. i recommend Motorhead to completely eliminate all squeaks and rattles. </div></BLOCKQUOTE>
The noise. My keys band the dash incessantly. Being moderately OCD, it drives me nuts. My wife doesn't notice.
Volume control would be an option...when I drive by myself, but if kiddo or wife are in the truck, that's not an option.
The padding on the dash mostly cures the problem. Instead of a loud clack, clack, clack, you get a much quieter thud, thud, thud that has fewer high frequencies to it and is easier for me to tune out.
BTW, it's not just during accel/decel for me. It's any time driving on uneven road, which is pretty much anywhere.
'03 pewter base H2
Old 12-15-2005, 02:25 PM
ree's Avatar
ree ree is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by ree:
... padding ... </div></BLOCKQUOTE>
'03 pewter base H2
Old 12-15-2005, 02:32 PM
It's been a long time since this subject has come up and the fixes are always the same.
Did I read something about a pad?
Old 12-15-2005, 03:06 PM
ree's Avatar
ree ree is offline
Being moderately OCD, it drives me nuts. </div></BLOCKQUOTE>
This truck will be drving you nuts if you keep it for more than a couple of years then </div></BLOCKQUOTE>
yeah I know. At 2 1/2 years old it already has plenty of noises.
I haven't owned any car that didn't drive me nuts, though.
I've managed to learn a coping technique called "enjoy being nuts."
At the risk of appearing to be a French wank sympathizer, cest la vie.
'03 pewter base H2
Old 12-15-2005, 03:10 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content"> but if kiddo or wife are in the truck, that's not an option </div></BLOCKQUOTE>
yeah, my wife doesn't like Motorhead either . .
Old 12-15-2005, 03:13 PM
ree's Avatar
ree ree is offline
yeah, my wife doesn't like Motorhead either . . </div></BLOCKQUOTE>
I don't like Motorhead either. But we all like a lot of other 80's rock and metal.
It's the volume the wife and kiddo don't approve of.
'03 pewter base H2
Old 12-15-2005, 03:18 PM
i found that Motorhead, while not being to everyone's taste, is the best at drowning out all clunks, rattles, squeaks and wind noise on a far more consistent basis. no chance of a quiet ballad coming up and allowing distracting noises to make it to your ear. and it leaves your ears ringing for a while, keeping you sane between tracks
Old 12-15-2005, 03:21 PM
ree's Avatar
ree ree is offline
... and it leaves your ears ringing for a while, keeping you sane between tracks </div></BLOCKQUOTE>
Ah. You need to pick up some progressive rock stuff (Dream theater is my recommendation) where they do a lot of 10-20 minute tracks.
'03 pewter base H2
Old 12-15-2005, 05:11 PM
mstams
Just keep trading. That's my solution.
Old 12-15-2005, 06:48 PM
I think I can hear someones bushings squeaking. Hmmm. Yep, I can hear it.
Old 12-15-2005, 06:53 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content"> I think I can hear someones bushings squeaking. </div></BLOCKQUOTE>
those would be mine, they're ready to disintegrate again.
Old 12-15-2005, 07:27 PM
Spike Spike is offline
I also have a fix for the remote banging....I superglued the key remote to the steering column and now it doesn't bang anymore....of course I have to leave the truck running constantly, but hey it was worth it!
