Old 11-19-2003, 03:20 AM
S/C H2 S/C H2 is offline
S/C H2 is off the scale
I have been working on this problem for a week now, maybe some one has some info. Under acceleration at 4200 rpm the engine cuts out and wont shift unless I back off the gas then it shifts fine and check engine light is on. I have the Paxton Novi 1200 series supercharger. Any suggestions are appreciated!
Old 11-19-2003, 07:55 AM
argonaut argonaut is offline
argonaut is off the scale
maybe take the supercharger off... ???
Old 11-19-2003, 11:05 AM
Patriot Patriot is offline
Patriot is off the scale
Buy a Whipple???
Sorry ...couldn't resist...
Sounds like an a knock sensor may be picking up some detonation and cutting power??
Old 11-19-2003, 01:11 PM
AUBURN H2 AUBURN H2 is offline
AUBURN H2 is off the scale
Did you use a reprogramer after you installed the Supercharger? Had a Whipple on one of my H2's and it ran terrible until I used the programer.
Old 11-19-2003, 04:08 PM
H2 Bill H2 Bill is offline
My guess is that the torque management is kicking in. I had the same problem with my Whipple and had do have the PCM custom tuned and the T/M removed. I had mine before Whipple had the programmer to fix the problem. If I were you I would buy the Predator programmer and that should solve your problem.
2003 H2 Hummer, Yellow,Polished Whipple Supercharged, Edelbrock ceramics, catback,18" Ambush w/mudders,lots of goodies!
Y2K Corvette Millennium Yellow Convert/Blk/Blk, B&B headers, B&B Tri-Flo's, H-Tech MAG,GMS MAF, RM Racing TwinFlow.
www.4swimwear.com
1994 Chev Suburban Blown
Old 11-20-2003, 02:27 AM
Thanks alot for all your help. I heard it was also plugged catalytic converters so we took the cats off and ran it down the street and the h2 ran and shifted like it should, so I will replace with new cats and muffler and should solve my problem.
Old 11-21-2003, 03:53 AM
well we put the new cats on today and it still acted up, so after 3 hrs of pulling hair my brother decides to go back to basics and found a plugged up fuel filter and cost $6.99 This fixed our problem and it runs great!!
