04-30-2006, 06:07 PM
I put them on recently tightened them down and their is some play forward to back by about 1" and they go back and forth as I drive and I am wondering why they are not stationary? Thanks
04-30-2006, 06:54 PM
They lock in place at only certain locations. Once locked, they shouldn't move.
04-30-2006, 08:12 PM
Can someone tell me where those locations are? This is driving me nuts!
04-30-2006, 08:19 PM
You have to look in the track for a notch about 1 inch , there are several running down the track. Line up with it they should be snug .
05-19-2006, 07:05 PM
Re: Roof crossbows rattling/moving
Hey Rhino,
Did you figure this problem out? I have mine arriving tonight and I want to avoid the same problem.
Thanks,
Chris
05-19-2006, 07:42 PM
No they still move back and forth around 1" on each side. They seem to lock down tight in the right spot then after a few days loosen back up. Maybe I got a bad set.
05-20-2006, 02:35 PM
Rhino...I'm having the same problem you describe.Even when the sliders are locked in the rail notches,there is some play there.I can't say that I have an inch of play,but there is some play there.In my opinion it's just a cheap design for such a good vehicle.
War is not hell...it's worse
05-20-2006, 02:48 PM
I can verify I do not have that problem, if anything they are hard to move when unlocked. I would take it to the dealer, they are not supposed to move after being locked in place.
05-20-2006, 03:24 PM
I would have to say this is my experience with them too.
05-20-2006, 05:29 PM
Ditto. You can always use blue locktight if they annoy you enough.
