Old 01-29-2006, 03:39 PM
Hoopte Hoopte is offline
Hoopte is off the scale
Just curious what type of radiator everyone uses. Do you just use the green old stuff or something else.
Anyone adds that Heat Reducing Additive?
[b]2004 H2 Black- <font color=red>Magnaflow Exhaust-</font> Black 18\' Helo Maxx8- <font color=red>BFG 35X12.50QR18</font>
Old 01-30-2006, 12:10 PM
Pink stuff called Dex-cool. do NOT mix with green stuff--nasty brown stuff is the result. If you're low, add water if you can't get the pink stuff.
Old 01-30-2006, 01:41 PM
Dewi2005's Avatar
Dewi2005 Dewi2005 is offline
Dewi2005 is off the scale
Planohummer is exactly correct.. Dex-Cool is the ONLY antifreeze that should ever be put in your Hummer cooling system. If you use the green antifreeze Im sure your warranty will be negatively affected!
03 Black Adventurer, Radix Supercharger, Corsa Exhaust, Edelbrock Headers, Air Raid Cold intake.
Old 01-30-2006, 05:39 PM
Thanks for the feedback
Old 01-30-2006, 06:30 PM
TXSUT's Avatar
TXSUT TXSUT is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Planohummer:
...add water... </div></BLOCKQUOTE>
Distilled water only.
Old 01-30-2006, 09:30 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Hoopte:
Just curious what type of radiator everyone uses. </div></BLOCKQUOTE>I use the stock radiator most of the time.
Old 01-30-2006, 10:15 PM
Dewi2005's Avatar
Just curious what type of radiator everyone uses. </div></BLOCKQUOTE>I use the stock radiator most of the time. </div></BLOCKQUOTE>
Most of the time??? do you have a switch on the dash to change which one you use??
Old 01-30-2006, 11:15 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Dewi2005:
Most of the time??? do you have a switch on the dash to change which one you use?? </div></BLOCKQUOTE>I don't use mine until it gets to about 180 degrees, so, until then it just sits there collecting dust.
