Go Back   Hummer Forums by Elcova > General Hummer Talk > Off-Roading
Old 05-28-2003, 01:12 AM
Phantasm Phantasm is offline
Phantasm is off the scale
I've done a fair amount of off-roading in northern Wisconsin with my beloved H2. On the last trip we encountered some deep water/mud/muck and, letting the testosterone take control of the situation, decided to go for it. Halfway through, we were mired up to the doorsills. Took two H1s to pull us out.
A couple of days later, the check engine light came on, so took the truck to the dealership. Bad knock sensor, replaced under warrantee. Two days later, check engine light came on again. Clogged evap vent, filled with mud and water. Replaced under warrantee. Three days later, light came on again. Some other plugged/blocked component, replaced under the warrantee.
Two days ago, the dealer (who has given the best service I've ever experienced in almost 50 years of driving) called. GM said the repairs should NOT have been done under the warrantee because it was obvious I had exceeded the stated specs/limitations of the truck. The dealer assured me that I would not be charged for the repairs, but essentially put me on notice that further repairs necessitated by exceeding the limits of the truck would be out of my own pocket. Can't really blame GM and I'm appreciative of the dealer's giving me the warning, which may be of value to all of us who like to get off the beaten path now and then.
Life is short - eat dessert first.
